Beginners Question, Cabinet Lists
skip fritz
Post by skip fritz »
Will ECabinet generate a list of cabinets used in a layout , on the layout ?(without me having to type it in as text)
Also Wiil E Cabinet geneate a list of what the cabinets are,when they are aytomatically numbered?
Skip
Justin Melhiser
Post by Justin Melhiser »
Skip
eCabinets will generate a cut list that will have the cabinets listed as (Cabinet No.1) directory/name of cabinet, then the size 41\"H X 52\"W X 18\"D, then tell if it is a (Base) or (upper). If you have any more questions feel free to email me or call me at 1-877-8804638 ext 227.
Thank You
Justin
Michael Yeargain
Post by Michael Yeargain »
Skip,
This may be complicated at first. But, here's how I do this.
After I generate my cabinet drawings I produce a cut list and export it to excel. (Free Open office will open this as well)
Next go to the sheet component listing and sort the end panels or something you know is on every cabinet. For example in the picture I knew every cabinet had a left end so sort the left ends and this will list the cabinets.
Now look in colum \"h\" or the 8th colum highlight the first and pull down to the last so the colum is highlighted as shown. Next select copy from the right click menu or ctr \"C\"
Then go back to the LDE and select the text button and right click on the screen and select paste...
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Michael Yeargain
e_cabinet ststems will then start typing in the copied text..
32Gigs DDR4
Corsair RM650
