Help with Profile Creator
Chris Robinson
Company Name: Chris Robinson
Post by Chris Robinson »
Hi Everyone,
I would like to attempt to make a top mount crown using the profile modeling within eCabs to see how it compares to my other cad/cam performance.
Would anyone care to take a look at it and make suggestions on how to proceed? This is the first time I have attempted to use the profile creator. Any suggestions on tooling?
Chris
True32 Crown.tol
(130.02 KiB) Downloaded 815 times
Michael Yeargain
Post by Michael Yeargain »
Chris,
You need to design the reverse for the profile. You are \"cutting away the molding\" and \"leaving the dust\" so to speak.
Also you will need to upload the .x_t file. not the .tol.
By the way. Great job for the first time.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Chris Robinson
Ok, here's the x_t file.
Chris
True32 Crown.zip
(29.9 KiB) Downloaded 835 times
Brian Shannon
Post by Brian Shannon »
I unzipped it and opened it in Shape Manager but didn't see anything.
Michael Yeargain
I can't see anything either... :?:
32Gigs DDR4
Corsair RM650
Brian Shannon
'Not sure but you may need to highlight the image(shape), then save as .x_t file.
Chris Robinson
Ok, let me try again. I must have opened the wrong file on my end.
I tried highlighting the profile and then saving as a x_t but still couldn't open the file in eCabs. So, I saved it as a dxf and it imported fine. The file that I have attached is a dxf file.
Chris
True32 Crown for eCab.zip
(5.74 KiB) Downloaded 790 times
Brian Shannon
That worked Chris. Make a .tol(@5.5 dia.) using your .dxf. I used a display panel that was 5 1/2\" x 96\". Take the panel into Part Editor, select Profile Edge, single, click on the bottom of the left edge. Find the tool you just made and set the right offset to 2.75, plunge depth to 1 1/16. This is just a starting point but you will see how it works and get the hang of it.
Brian
Crown Top Mount.jpg (41.85 KiB) Viewed 10682 times
Michael Yeargain
Works fine.
Now you need to create the back cutter to get the proper profile, if you want to get that detailed with the molding.
For whatever it's worth the profile will show great unless you look at the top of the cabinet behind the molding.
You can also move the actual dxf import to the right by 2 3/4\" and save the tol file. Using move increment. Then you won't have to do the offset.
Overall great job.. :wink:
32Gigs DDR4
Corsair RM650
Chris Robinson
Ok, I've got it. I understand how to create the modeled part. Now for the THM Control. I have installed the latest Profile Modeler version.
Reading through the manual, and looking through the setup at the control, I see that I can define 3 types of tools, right? A custom tool - which has the defined shape, like a panel raise tool. The other 2 types would be under Modeling, either Square Edge or Radiused edge. So, this means that the control wouldn't be able to use a vtool or a liner tool to clean out corners. What I'm saying is that I wouldn't be able to define a Liner tool like a SESLIN062 tool. Am I correct? Or would I have to set up such a tool as a \"Custom Tool\" and assign it to a specific area of the modeled part?
Maybe it's easier to ask that anyone that's used the Profile Modeling function on the THM, how would you approach this?
Chris
Brian Shannon
You are correct about the tooling setup. It looks like they set it up for a pointed bit(45 or liner) to be used in the future. I guess you could setup your liner as a custom tool. You might try just setting your liner bit as a ballnose with a 1/16\" dia.(or less) and see what that does.
