Reindeer
Joe Soto
Re:
Post by Joe Soto »
DanEpps wrote:
On the create part thing, you might try it again and just let it sit. It has so many points that it could take a while to complete.
sometimes I have to hit the return button for it to show the change. Joe
Brian Shannon
Post by Brian Shannon »
I always have to move the cursor to show the change.
Damon Nabors
Post by Damon Nabors »
I have sat there and hit every button I know to hit.
When I chose the part out of the nest and click closed contour shape, then go to the bottom and click NEXT the Next button changes shape with a box surrounding it, but the next button doesn't ever go away. It just stays there. The other parts the NEXT button would disappear and then the part would pop up out of the nest.
Joe Soto
Post by Joe Soto »
I'm not sure why one body won't work, but you could just copy and paste the other one
Damon Nabors
They are two different bodies, one is leaning down and the other is looking up.
SUPPORT AMERICA AND BUY AMERICAN
AMERICAN MADE.JPG (708.23 KiB) Viewed 14230 times
DEER CUT OUT.JPG (726.06 KiB) Viewed 14230 times
Wow...a 14-pointer!!! :shock:
Try doing a chain select on the other body and see if it has any open contours.
Here is an x_t file that you can use to create the other deer.
OneDeer.zip
(27.81 KiB) Downloaded 870 times
deer 2.jpg (20.68 KiB) Viewed 14222 times
deer 1.jpg (126.71 KiB) Viewed 14222 times
Damon Nabors
Ok Dan, you did it to me again. I am slow with the whole file thing, but once someone shows me I catch on fast.
I down loaded the x_t file under My Tools in shape manager. Now what do I do with it. (Its kind of like a dog chasing a car, if he caught it he wouldn't know what to do with it :) :D :shock: :idea:
I can pull it up under shape manager. But I do not see any other places to open a X_t file.
One of you guys out there needs to write an e-cab file managment for DUMMIES book. I know I would buy one.
Joe Soto
Post by Joe Soto »
Dan will beat me to this but anyway, where you have been loading the dxfs in the part editor look in my tools and change the type of file you are looking for to .x_t ( near the bottom)
Dan, did you find a break in the outline? I was getting the same as Damon in e-cab so I just loaded the dxf at the control and it sees it as closed and will nest it.
Nope, I couldn't find any breaks at all. It is a lot faster to create the part with just the single body as an x_t.
Damon Nabors
Thanks everyone. I finally have it. I could have sworn I tried to change the file type awhile ago. But maybe I didn't. Now I feel kind a like Duhhhh!
Damon Nabors
Thanks Dan and Joe,
We have repopulated another Deer
grazing deer.JPG (926.88 KiB) Viewed 14202 times
Brian Shannon
Very cool Damon. I may have to make some for my grandson. Extira MDF would be good for these although expensive.
Damon Nabors
Brian,
These where made from scrap. I am still toying around with the router since we have only had it for a week now.
If I where going to make some to keep, I would make them from 1/2\" MDO.
Sign makers use it all the time for exterior. I think a 4x8 sheet of 1/2\" is $35.00. Thats not too bad, $17.50/deer.
Brian Shannon
I wonder if MDO is the same as Extira. Also, 3/4\" may be required for fit. Looks great. Keep it up.
