Molding
Damon Nabors
Molding
Post by Damon Nabors »
Is it the way I am doing it or is this a problem. When I have an upper cabinet and I plan to put a finished end panel on one end of the cabinet. I go to the face frame allow a left or right scribe of .75 to move the end gable inwards. The problem comes when I try to add the upper crown. It installs next to the gable and not the style. I understand why because it is a scribe, and I under stand that I can allow a left or right scribe on the front molding to bring it out flush with the end of the style, but other than bringing the side moldings in manually, how do you offset the side molding to line up with the scribed front molding? I know how to do this the hard way manually, but there has to be an easier way that I am overlooking.
Damon
molding issue.jpg (150.06 KiB) Viewed 10980 times
Remove your moldings, set the scribe on the front molding then add the top molding. It will now have the correct positioning.
Nevermind that answer...it does not correctly place the side molding. You will have to manually place the side molding.
Damon Nabors
No simple way to do this. It would be a nice fix to not have to manually place these molding. To me it would be easier to be able to apply the moldings and if you want to inset the side gables be able to go into settings and inset the sides, rather than having to do the scribe thing with the faceframe.
Damon,
I leave the molding off the end of the cabinet where the finished end goes, then set a scribe to lengthen the top molding and add the end molding to the finished end with an appropriate scribe. You then have all the moldings when you add the end panel.
Damon Nabors
Thanks, Kerry and Dan
Michael Yeargain
Post by Michael Yeargain »
I like that idea Kerry.
I have a directory of just moldings that I can run just like the cabinets all the way around the room.. Left ends, right ends straight runs. Even the corner cabinets.
It makes it a little easier for me.
But with the new and improved... look out moon.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
You know, there was another thread about creating a body-less cabinet with top molding so it could be resized. Everything but the top was deleted and molding was added. I'll see if I can find it so you will have another method to try.
Damon Nabors
Thanks Dan, that was an interesting thread. I guess part of the learning process is learning to think outside the box.
Happy Thanksgiving to all and be carefull if you and your families are traveling.
Damon
Michael Yeargain
Dan has a saying for this.
32Gigs DDR4
Corsair RM650
Re:
Michael Yeargain wrote:Dan has a saying for this.
You mean "use common parts in uncommon ways?" :wink:
Michael Yeargain
Yep that be it.. :D
32Gigs DDR4
Corsair RM650
