help with part editor
wayne chater
Post by wayne chater »
I feel like I've mastered just about every other aspect of the program but theres something about part editor that I just dont get. I've read the help manual many times but it seems too general. I need a tutorial that leads me through it step by step. is there such a thing?
specifically I want to create a curved counter top and curved island front.
I have managed to create a flutted filler (dumb luck?)
Terry Davis
Company Name: Penn Laminates
Post by Terry Davis »
You will probably have to use display cubes you can give them just about any shape, color and texture you want, and curved walls are not supported yet.
wayne chater
I think your right about the display cube but I haven't been able to edit the part. I get left with the waste instead of the counter. I seem to be able to put the lines where i want to cut but then I'm lost. there is somthing fundamental about part editor I'm just not grasping.
Paul Ellis
Post by Paul Ellis »
Wayne,
After creating the contour you want, right click and then choose 'Create part using closed contour', click on the contour line and then click next. You should now be left with the part you want. You probably chose the other one where you can cut through the material.
HTH
Paul
Paul Ellis
"If it works, don't fix it"
Wayne
eCabinet Systems Made Easy (located on the help menu) gives a great tutorial on making curved parts.
Click the Contents tab then scroll down to \"Using the Cabinet/Assembly Editor\" and double-click it. Scroll down to \"Using the Part Editor\" and the right panel has the steps.
curved part.jpg (228.29 KiB) Viewed 15195 times
made Easy.jpg (112.65 KiB) Viewed 15195 times
wayne chater
Thanks Dan & Paul: I haven't had time to play but this looks like what I need.
Regards, Wayne
I just added a video demo of how to do this to eCabWorld. Go to the Downloads section of the Member's Lounge to download the file.
It is a 7.35MB zip file and requires Windows Media Player to play (WMV file).
Keith Beggarly
Quick sample of ctop
Post by Keith Beggarly »
Looks like you have been given good instruction. Here is a quick example of what can be done.
Giallo Vene ctop sample.jpg (93.25 KiB) Viewed 15133 times
