trouble shooting ??
gaynelle crofts
trouble shooting ??
Post by gaynelle crofts »
I am new to the software. I have created a couple of really basic/simple designs. I am trying a new one and I am having troubles selecting an area to add a door.
I have done it before, and I am afraid I am just being clueless!!!
I am working with an assembly. I start in the main area. Select the cabinet, go to door designer. My cabinet stays highlighted and I cannot select a specific area to add a door. It will add a door, but only to the entire cabinet. I only want it in a particular area.
I have rebooted and still no help!
Any help would be wonderful as I am suposed to have this design yesterday.
ps you guys do some amazing things, I can't wait to do half of what I see on here.
gaynelle
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
Post by Glenn Van Reason »
Can you post up what cabinet/assembly your working on and an idea of where you want the door. I'll have a look
Joseph Fusco
Post by Joseph Fusco »
gaynelle,
You need to give the software a defined boundary for where you what the door to be. If you have a cabinet with a fixed shelf in the middle, you can place two doors on it. If the shelf in the middle is adjustable, the software will only put one door on the whole box.
Joseph Fusco
Pic's
gaynelle,
take a look:
Joseph Fusco
This is the first pic.
gaynelle crofts
Re:
Glenn Van Reason wrote:Can you post up what cabinet/assembly your working on and an idea of where you want the door. I'll have a look
I could if I knew how ;0
Let me see if I can figure it out.
Did it work?
gaynelle crofts
Re:
Joseph Fusco wrote:gaynelle,
I am trying to highlight the area I want the door to go on and it won't let me. The cabinet stay highlighted green. When I try to click on the area I want to add the door to it does nothing.
FYI-same thing happens in the shelf/partition editor.
Make sure you go into the Door/Drawer Editor after selecting one of the cabinets in the assembly.
door editor.jpg (138.65 KiB) Viewed 14243 times
gaynelle crofts
Re:
DanEpps wrote:Make sure you go into the Door/Drawer Editor after selecting one of the cabinets in the assembly.
yep...did that and I have those buttons. it will let me add a door that is the entire height of the cabinet. It won't let me select the lower sections to add doors down there.
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
You need to have a fixed shelf designating the two separate areas.
gaynelle crofts
Re:
When I hit ESC to deselect the highlighted area it does not deselect.
gaynelle crofts
Re:
Glenn Van Reason wrote:You need to have a fixed shelf designating the two separate areas.
yep..got that...
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
Can you attach the assembly file, or the cabinet that your having trouble with?
gaynelle crofts
Re:
Glenn Van Reason wrote:Can you attach the assembly file, or the cabinet that your having trouble with?
like this????
Glenn Van Reason
Company Name: TBA
Country: AUSTRALIA
No that is just a picture of the cabinet, I need the actual hsf file of the cabinet so I can open it in eCabinets and try it out
