BenRatt
Posts: 170 Joined: Sat, Oct 22 2005, 10:59AM
Post
by BenRatt » Mon, Jan 14 2008, 5:27PM
Why can't I change the faceframe width? When I pull up screen 2 of the FF settings there is no column for FF width.[attachment=0]ff width.doc[/attachment]
ff width.doc
(33 KiB) Downloaded 696 times
Damon Nabors
Posts: 923 Joined: Wed, Apr 05 2006, 5:50PM
Post
by Damon Nabors » Mon, Jan 14 2008, 5:49PM
It looks like you have cropped the image. "page two" is normally centered in the window and it is off to one side as if something is blocking the image or edited. The blue question mark is missing, define materials is missing, ok /cancel is missing, go to page one is missing?????
Are you in Face frame editor or main screen? Have you tried it in both locations?
Damon Nabors
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Mon, Jan 14 2008, 7:42PM
Make sure your screen resolution is set to 1024 X 768
BenRatt
Post
by BenRatt » Tue, Jan 15 2008, 5:11PM
Nope, the image is not cropped and changing the screen resolution doesn't help. Does anyone else have this problem??
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Tue, Jan 15 2008, 6:24PM
Ben
Do you have the same problem if you start with a standard frameless base and go into Construction Settings -> Face Frames?
Justin Melhiser
Post
by Justin Melhiser » Wed, Jan 16 2008, 8:55AM
Ben
What kind of graphics card do you have and what memory size is it?
BenRatt
Post
by BenRatt » Wed, Jan 16 2008, 8:57AM
Yes, I tried a standard frameless cabinet and turned the faceframe on and off and in both instances, the option to change the width of the face frame wasn't available.
BenRatt
Post
by BenRatt » Wed, Jan 16 2008, 9:06AM
Here's the graphics card info[attachment=0]graphics card.doc[/attachment]
graphics card.doc
(99 KiB) Downloaded 659 times
Justin Melhiser
Post
by Justin Melhiser » Wed, Jan 16 2008, 9:10AM
Ben
I am going to give you a call in just a minute. I will try to work through some things over the phone to get your software working properly.
Post
by DanEpps » Wed, Jan 16 2008, 9:11AM
The graphics card shouldn't have anything to do with whether all of the dialog shows or not.
I would say the best thing to do is to call eCabinets Technical Support for advice.
Justin Melhiser
Post
by Justin Melhiser » Fri, Jan 18 2008, 12:59PM
Ben
I wanted to check and see if running a repair fixed this or not. Please let me know.
