faceframe width doesn't work
BenRatt
Why can't I change the faceframe width? When I pull up screen 2 of the FF settings there is no column for FF width.[attachment=0]ff width.doc[/attachment]
- Attachments
- ff width.doc
- (33 KiB) Downloaded 674 times
- Damon Nabors
Re: faceframe width doesn't work
It looks like you have cropped the image. "page two" is normally centered in the window and it is off to one side as if something is blocking the image or edited. The blue question mark is missing, define materials is missing, ok /cancel is missing, go to page one is missing?????
Are you in Face frame editor or main screen? Have you tried it in both locations?
Damon Nabors
- Kerry Fullington
Make sure your screen resolution is set to 1024 X 768
BenRatt
Nope, the image is not cropped and changing the screen resolution doesn't help. Does anyone else have this problem??
- DanEpps
- Company Name: Dan Epps
Ben
Do you have the same problem if you start with a standard frameless base and go into Construction Settings -> Face Frames?
Justin Melhiser
Ben
What kind of graphics card do you have and what memory size is it?
BenRatt
Yes, I tried a standard frameless cabinet and turned the faceframe on and off and in both instances, the option to change the width of the face frame wasn't available.
BenRatt
Here's the graphics card info[attachment=0]graphics card.doc[/attachment]
- Attachments
- graphics card.doc
- (99 KiB) Downloaded 634 times
Justin Melhiser
Ben
I am going to give you a call in just a minute. I will try to work through some things over the phone to get your software working properly.
- DanEpps
The graphics card shouldn't have anything to do with whether all of the dialog shows or not.
I would say the best thing to do is to call eCabinets Technical Support for advice.
Justin Melhiser
Ben
I wanted to check and see if running a repair fixed this or not. Please let me know.
