end panels....HELP!
Brian Bauer
end panels....HELP!
Post by Brian Bauer »
Hello,
I have a question about end panels. When an upper cabinet intersects with a fridge cabinet,Do you make and "ELL" shaped panel,I am talking recessed shaker style here.
Or do you just leave it flat plywood?
Any ideas or sample dwgs would sure help.
Thanks a bunch guys.
Brian
Mike Seisser
Company Name: NCB Inc.
Re: end panels....HELP!
Post by Mike Seisser »
It would depend on the distance between the face of the fridge cab and the face of the upper. It's also a matter of personal taste. I would see nothing wrong with a flush panel on the side of that fridge cab.
Brian Bauer
Mike,
I was just wondering, It might look cool! probably different too. i have never seen one myself.
Did you buy a router?
PM me if you did.
brian
Lee Gernandt
Post by Lee Gernandt »
I usually make the upper over the refrigerator 24" deep and will at times have a panel on that portion that sticks by the standard 12" deep upper. When my customers order the matching end panels, they like the fact that wy give them just that little bit more than what they were expecting.Plus, I think it looks cool.
Lee
Brian Bauer
Lee,
Is it an L shaped panel? do you have a rendering of one? i think it might look cool too,plus it wouldn't leave an unfinished end.
Thanks Brian
Lee Gernandt
Sorry, no renderings. The panel is just on the part that sticks past the upper.
Lee
Gene Davis
Post by Gene Davis »
Like this?
Paneled fridge end.jpg (31.44 KiB) Viewed 13980 times
Mike Seisser
Brian Bauer wrote:Mike,
PM me if you did.
brian
I haven't yet, but funny you should ask as I'm in the process of moving my small shop into a much nicer space and partnering up with 2 other guys. I've made a router my 6 month goal.
Damon Nabors
Post by Damon Nabors »
Brian, is this what your looking for?
Ell cabinet.jpg (36.66 KiB) Viewed 13936 times
Damon Nabors
Damon Nabors
Sorry, I forgot you wanted a shaker style.
Damon Nabors
Brian Bauer
Damon yes that is what I'm looking for ,but with two panels instead of one.one under the upper cab and one long one beside it. How does one go about making that piece also.?
Brian
Damon Nabors
Brian, the first image, I brought in a display panel and took it to the parts editor and machined the raised panel. You can make pretty much any shape you want.
The easiest way to make two seperate panels is to bring in two doors and mesh them together to get the look you are looking for. In this picture I am using a 25.5" deep refridgerator cabinet so that my granit doesn't stick out there ( I hate that), and I placed a 12.75x34" door on the side of the cabinet and then placed a 24.75x 19" door just below the other door and lined up the styles to make them look as if they are one end panel. Oops, just noticed my back splash is not touching the wall.
Hope this helps,
Damon
Damon Nabors
Brian Bauer
Thanks Damon ,
I love it,the two panel wider at the bottom,great idea! i will put it in the proposal and see if it flys.Maybe i will pretty this one up and send it to jason for the next e cab mag.
Brian
Damon Nabors
good luck, go for it!!!!!!!!
Damon Nabors
