After installing the 5.2 update I now have an error in the drawer box editor. When I add a drawer box the first message reads; "Failed in generating CNC data." I hit OK and this message pops up; "There was an unexpected error while handeling CNC data operation in Drawer Box edditor. Reverting to previous body." The drawer box is then added but it looks like the attachment. Is anyone else having this problem??
DRAWER BOX ERROR.jpg (18.65 KiB) Viewed 10101 times
The dado settings you are using on that drawer box are causing the problem. You will have to recreate your drawer box using the STD drawer box not any of the STD dovetail drawer boxes. I’ve got this listed for the programmers, sorry for the inconvenience.
Hey Walter,
Speaking of drawer box. When I place a drawer base cabinet and I have to resize, the drawer box does not resize with it. Is there something that I can do, or is there something that I am not doing?
Thanks!
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Are you using the drawer box that you get the error from? Do you have minimum increment set for the drawer box that is not resizing correctly? Could you attach the cabinet with the drawer box before you resized it?
