DRAWER BOX ERROR
jerry johnson
DRAWER BOX ERROR
Post by jerry johnson »
After installing the 5.2 update I now have an error in the drawer box editor. When I add a drawer box the first message reads; "Failed in generating CNC data." I hit OK and this message pops up; "There was an unexpected error while handeling CNC data operation in Drawer Box edditor. Reverting to previous body." The drawer box is then added but it looks like the attachment. Is anyone else having this problem??
DRAWER BOX ERROR.jpg (18.65 KiB) Viewed 10092 times
8)
Walker T Scott
Re: DRAWER BOX ERROR
Post by Walker T Scott »
Could you attach the cabinet file then the drawer box file too?
jerry johnson
apple .485 PREFINISHED TANDEM BOX .5 BOTTOM.hsf
(52.02 KiB) Downloaded 861 times
DRAWER ERROR.hsf
(1.49 MiB) Downloaded 854 times
I hope I did this right. Thanks! 8)
Walker T Scott
The dado settings you are using on that drawer box are causing the problem. You will have to recreate your drawer box using the STD drawer box not any of the STD dovetail drawer boxes. I’ve got this listed for the programmers, sorry for the inconvenience.
Sergio Fetter
Company Name: Two Mile
Post by Sergio Fetter »
Hey Walter,
Speaking of drawer box. When I place a drawer base cabinet and I have to resize, the drawer box does not resize with it. Is there something that I can do, or is there something that I am not doing?
Thanks!
Sergio Fetter
Designer Specialist
Ram 3GB - Windows 7 32-bit
Walker T Scott
Are you using the drawer box that you get the error from? Do you have minimum increment set for the drawer box that is not resizing correctly? Could you attach the cabinet with the drawer box before you resized it?
Sergio Fetter
Here it is.
Let me know the outcome on that.
Thanks again!
DB21.hsf
(2.13 MiB) Downloaded 671 times
Sergio Fetter
Designer Specialist
Sergio, it resized for me OK.
Sergio Fetter
Rick,
I appreciated. I am not sure what I did there for a few minutes.
Thank you!
Sergio Fetter
Designer Specialist
Lamar Horton
Post by Lamar Horton »
That was happening to me as well. I would delete the drawer in the Door Drawer Editor the re choose the default drawer box and it works fine.
That's weird, cause I just adjusted the width of the cab and it followed along like it should.
