Panel front.
Greg Haw
Panel front.
Post by Greg Haw »
Trying to design a cabinet with no doors on the front just 4 panels. Is there a way to do this? I am just learning the software Just so you know. I tried overlapping door to get rid of the extra style. That didn't work to well. Any other ideas?
Damon Nabors
Re: Panel front.
Post by Damon Nabors »
Are you trying to get a wainscot effect?
Damon Nabors
Greg Haw
Re: Panel front.
Post by Greg Haw »
Yes that's what I am trying to do
Damon Nabors
Re: Panel front.
It can be done. If the individual grain direction of rails and styles is not a major factor, the easiest way is to model a part in the parts editor. Or you could do an applied molding with a big spider in the middle like this. :?
SPIDER WALL.jpg (43.91 KiB) Viewed 21922 times
Damon Nabors
Re: Panel front.
This is another way to do it Greg. I use a faceframe cab, remove all the parts except the back and frame. Make the frame from 1/4" sheet stock and the back from 3/4". Set the cab depth at 1". Now you can go to the faceframe editor and do whatever you want. Save as a panel, and resize as required. HTH
panel.hsf
(162.02 KiB) Downloaded 1152 times
Damon Nabors
Re: Panel front.
Just got back home and cleaned up the spider webs off the wall. This is the other way of doing it.
SPIDER WALL2.jpg (27.42 KiB) Viewed 21893 times
Damon Nabors
Re: Panel front.
Artcam?
Damon Nabors
Re: Panel front.
The spider was created in artcam, the rest was just moldings created in ecab.
The last one was just a cab with the geometry drawn on the back of a cabinet and then move the back forward to the front of the face frame.
Damon Nabors
Re: Panel front.
Greg,
I use the face frame method. Set your face frame to the sizes you want your stiles and rails. I add a negative inset the length of the cope tongue (either 3/8" or 1/2") to get the lengths of the parts correct. I then inset MDF doors (create a sheet material like 3/4" oak lumber) using a negative gap needed to put the panel into the groove (-5/16" for me) and I use a G-Cove tool to create the outside profile of the mdf doors. Now you can add or subtract panels and everything will re-size. This also gives you a correct cut list.
I also created cope and stick profiles to run on the stiles and rails if I am going to do a closeup in presentation view but it is normally too much trouble to do this.
Damon Nabors
Re: Panel front.
I found it easier to just apply the geometry to the back of the cabinet and then just move the back forward with a back inset. If you want to re size the cabinet, just change your settings in the constraint manager.
Damon Nabors
Re: Panel front.
Damon,
Do you get correct cutlist for your panels using the back?
Damon Nabors
Re: Panel front.
Kerry Fullington wrote:Damon,
I guess there is a statement in the middle of that question! :)
Damon Nabors
Re: Panel front.
Sorry Damon,
It should have read,
"How do you get a correct cutlist using the back?"
Damon Nabors
Re: Panel front.
I know Kerry, I am just poking fun. You can't get a cut list.
But if it was me, and I know the opening is say 15 x 24, I am going to know in my head from doing this for so long and knowing the formulas for my shaper tools. That panel is going to be 15 7/8 x 24 7/8, and I can use the cut list for the rails and stiles from the face frame. I just need to add to the length of the rails and any mid styles for the cope and stick profile of my cutter.
Damon Nabors
Greg Haw
Re: Panel front.
Post by Greg Haw »
Well ok , Like I said I am just learning the software and don't fully understand much of what was said. I do thank you all for the replies and education. I am just going through old jobs and redoing them in ecabinets to learn the software. If my drafting skills were better I think I would stick with that. Damon: Do you mean drawing geometry on the back panel as in using the part editor to do so?
Kerry not sure I understand "I add a negative inset the length of the cope tongue (either 3/8" or 1/2") to get the lengths of the parts correct." I assume that is done in construction settings. and I create a slab door and install it inset into the face frame ? Well I will try to figure some of it out, And once again thanks to all
Greg
