Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Fri, Jan 02 2009, 5:10PM
Did you save it as an HSF? If so, where did you save it? The image file will be in the same location and have the same name (with a .jpg extension instead of .hsf) as the HSF file.
Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Fri, Jan 02 2009, 5:20PM
Yes I did save it as a HSF, and the jpeg file is right next to the HSF file. The jpeg is just a white square
Post
by DanEpps » Fri, Jan 02 2009, 5:40PM
Post a copy of the HSF.
Gary Puckett
Post
by Gary Puckett » Fri, Jan 02 2009, 5:55PM
Dan,
Here is the file and all the HSF files look this way
bas-cl3.hsf
(146.02 KiB) Downloaded 809 times
Post
by DanEpps » Fri, Jan 02 2009, 6:42PM
There is no JPG with the same name?
Here is what I did to get the JPG:
1. Load HSF into Display Part Editor
2. Click "Save"
3. Select "import\Sample_HSFs" folder
4. Enter filename (I used "corbel")
5. Click "OK"
Now I can load the corbel from the "Display Objects" selection dialog.
Gary Puckett
Post
by Gary Puckett » Fri, Jan 02 2009, 7:28PM
Did you want the jpeg file too?
That is what I did when I converted the 3d DWG file to a STL file.
Do you see in your post how you put a red circle around the fluted column, well when I do that at my end all I see is a white or black square with the name. But when I select it to use in a drawing it shows up.
Post
by DanEpps » Fri, Jan 02 2009, 7:32PM
So, the only place you don't see the image is in the selection dialog?
Post
by DanEpps » Fri, Jan 02 2009, 8:06PM
DanEpps wrote: So, the only place you don't see the image is in the selection dialog?
I tried it on a Vista system and see what you are talking about now. The image file itself is only a blank white square, regardless of whether you see it in the selection dialog or with the Windows file browser.
The JPG file is there but is just blank.
Posts: 4764 Joined: Mon, May 09 2005, 7:33PM
Post
by Kerry Fullington » Fri, Jan 02 2009, 8:35PM
Vista is EVIL
Gary Puckett
Post
by Gary Puckett » Fri, Jan 02 2009, 9:51PM
But Dan the image has to be some ware how can you find it. NOw go to eCab.on your Vista vesion pull up a standard cabinet wall base it doesn't matter and try to use the camara. Does it work?
Vista Man(Gary)
Joseph Fusco
Posts: 71 Joined: Tue, May 17 2005, 2:19PM
Post
by Joseph Fusco » Fri, Jan 02 2009, 10:32PM
I get a black square in Vista, but the funny thing is I can't see either file (jpeg or hsf) in windows explorer. If I load the file from within eCab it works just fine. . .
Gary Puckett
Post
by Gary Puckett » Fri, Jan 02 2009, 11:05PM
OK heres what you have to do to get the image to show up
1) Load the HSF file in the cabinet editor and save it as an assembly
2) Now go to c/program files/Thermwood/eCabinets
3) Go to the assembly folder copy the HSF image you saved as an assembly
4) Now go to the import folder right click on the folder and paste the image
SHAZAM the image is now visable.
Thank you Thank you I'll be here all week
The Vista Man ( Gary )
Damon Nabors
Posts: 923 Joined: Wed, Apr 05 2006, 5:50PM
Post
by Damon Nabors » Sat, Jan 03 2009, 12:52AM
Gary,
Looks like All you needed to do was make sure your information is in the correct folder.
Kerry Fullington wrote: Vista is EVIL
Kerry,
Vista sounds like a bad apple to me.
Damon Nabors
Post
by DanEpps » Sat, Jan 03 2009, 9:32AM
Damon Nabors wrote: Vista sounds like a bad apple to me.
Sour grapes maybe?
I just can't wait for Windows 7...or is it Vista minus? I guess changing the standard location of files is progress to Microsoft.
