Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Fri, Jan 09 2009, 10:35PM
The Cabinets acn be resizes width and height. Insides are made of stretchers T_1/64"
they will not work on the depth. You would have to change the depth of the stretcher
1-9-09 Resize Cabinets.jpg (44.76 KiB) Viewed 3746 times
Georgi Baltov
Posts: 341 Joined: Sat, Mar 10 2007, 7:31PM
Post
by Georgi Baltov » Sat, Jan 10 2009, 9:26AM
George that's looking great but I would rather get it the other way around. While on the inside and then any grain on the outside.
Can it be done? Again being able to resize the width.
Post
by George Davidson » Sat, Jan 10 2009, 12:44PM
The depth you can not change. The size of the whiteboard has to be changed before you change the depth
The width and height can be change to any size
Corner Cab_1.jpg (99.12 KiB) Viewed 3676 times
Post
by George Davidson » Sat, Jan 10 2009, 1:58PM
Corner Cab liner the liner can not be resized. You would have to make a new liner for each corner cabinet
Corner Cab_4.jpg (57.43 KiB) Viewed 3664 times
Corner Cab_3.jpg (40.2 KiB) Viewed 3664 times
Corner Cab_2.jpg (34.18 KiB) Viewed 3668 times
Georgi Baltov
Post
by Georgi Baltov » Mon, Jan 12 2009, 10:40AM
They look great George. Good idea to use thin stretchers
