Cabinets White on out side grain in side
The Cabinets acn be resizes width and height. Insides are made of stretchers T_1/64"
they will not work on the depth. You would have to change the depth of the stretcher
1-9-09 Resize Cabinets.jpg (44.76 KiB) Viewed 3745 times
Georgi Baltov
Re: Cabinets White on out side grain in side
Post by Georgi Baltov »
George that's looking great but I would rather get it the other way around. While on the inside and then any grain on the outside.
Can it be done? Again being able to resize the width.
The depth you can not change. The size of the whiteboard has to be changed before you change the depth
The width and height can be change to any size
Corner Cab_1.jpg (99.12 KiB) Viewed 3675 times
Corner Cab liner the liner can not be resized. You would have to make a new liner for each corner cabinet
Corner Cab_4.jpg (57.43 KiB) Viewed 3663 times
Corner Cab_3.jpg (40.2 KiB) Viewed 3663 times
Corner Cab_2.jpg (34.18 KiB) Viewed 3667 times
Georgi Baltov
They look great George. Good idea to use thin stretchers
