Hardware DB Changes & Error
Gary Campbell
Post by Gary Campbell »
V6b2b has had some changes to the hardware DB.
All of the existing Listed Manufacturers are now classified as "legacy" and cant be deleted? IS there any reason for this that I am missing? I use 10 and may build to 20, but normal use is 5 or less. Build 1 allowed deletion of unused items.
Second, I tried to change the file picture attached to a straight arm hinge with an accurate one. and after 10 error dialogs in a row received this one which required using tskmgr to close the app an lose my changes. What am I missing and/or doing wrong?
Hardware Error.PNG (23.06 KiB) Viewed 8681 times
EDIT: There were additional blank dialogs buried under the main window that became visible when app was closed. It took multiple tries with tskmgr to close these also. eCabs wouldnt restart before OS was rebooted. Upon reboot and restart of eCabs, all changes made to Hardware Mfgrs, products, websites, Vendor info was lost.
Gary Campbell
Company Name: Halls Edge Inc
Re: Hardware DB Changes & Error
Post by Josh Rayburn »
Hi Gary,
Legacy information indicates that some of the manufacturers' information in the hardware database has links to other parts of the software.
In Build 1, I deleted the vendor Conestoga, because I never order anything from them so I tried to pare down the list a bit.
That ended up causing major problems, one of which was that all the doors and drawer fronts, when selected as Conestoga, would fail to work entirely.
This was a bad bug, so now any manufacturers, or any other data that contains that 'legacy information' is protected.
Hope that helps,
Gary Campbell
Josh...
Thanks for the explanation. I, like you, cleaned out a large number of vendors or mfgrs in build 1. I didnt try to delete any mfgr that had an item in the DB, just ones with zero values that I would never use. I added all my required hardware items to the DB over the weekend, I have 53. I may have 100 some day, but dont think so. I do have 3 times that many hole patterns, as that is what matters to our jobs.
So now my DB has 53 user items, 105 for Connestoga (OK) and 49 from the TWD Furn. NEtwork (OK, but unsure if I will ever use them) But I do have a list that is uneditable of 52 Mfgrs that have legacy requirements , but zero entries. Seems that in order to make something perform better, stripped down is faster than bulked up.
Gary Campbell
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
There will be more work done in this area. One thing that may come down the line is allowing the user to "delete"(hide) the legacy items. The legacy item would not be deleted from the database, but it would not be display in the Hardware window.
Rick Deskins
Bryan J Tanner
Company Name: Decor Designz
Post by Bryan J Tanner »
That sounds like a great idea!! :beer:
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
I like that idea too!
:beer:
One more vote yes.
Gary Campbell
I may as well get officially on the side of deleting (hiding) them too
Gary Campbell
Sean Jakob
Company Name: Sean Jakob Cabinets
Post by Sean Jakob »
Me too
