I have attached a cabinet that I am trying to add a 2.5" stretcher to the bottom front of the cabinet as a TK. I want this TK to be inset .25" with a KD/RTA fitting on either side. What I have done in the past is give the front inset of -1" for both the Right and Left KD/RTA Placements and the back @ 1.25"
As soon as I do this, I lose all KD associations and Dwr Slide associations. Then when I go to the associations and re-apply the slide associations it will add them back but then when I add the kd associations the slides go away.
Any ideas what is wrong with this cabinet???
-John
I just took this cabinet in and added a TK in the construction settings and when I came back into the cabinet editor, it lost all the hole associations.
Do you have a version of this cabinet that still has the patterns in it? This cab has the file name for the patterns showing, but the patterns do not actually exist within the cab. I may need more info from you. Did all the work/changes to this cab occur directly in the cab/assm editor, or was it pulled from a room/batch and then modified/changed etc.?
