Losing Hole Associations
JohnLashuay
Post by JohnLashuay »
I have attached a cabinet that I am trying to add a 2.5" stretcher to the bottom front of the cabinet as a TK. I want this TK to be inset .25" with a KD/RTA fitting on either side. What I have done in the past is give the front inset of -1" for both the Right and Left KD/RTA Placements and the back @ 1.25"
As soon as I do this, I lose all KD associations and Dwr Slide associations. Then when I go to the associations and re-apply the slide associations it will add them back but then when I add the kd associations the slides go away. :wall: :wall: :wall:
Any ideas what is wrong with this cabinet???
-John
Hutch_19x84x25-5_6-6-8-8_Bad.hsf
(1.92 MiB) Downloaded 371 times
http://www.rylexonline.com
Thermwood CS 43
JohnLashuay
Re: Losing Hole Associations
By the way...I am running v6.4
Thermwood CS 43
JohnLashuay
I just took this cabinet in and added a TK in the construction settings and when I came back into the cabinet editor, it lost all the hole associations.
This doesn't make any sense to me!!!
-John
Thermwood CS 43
Scott G Vaal
Post by Scott G Vaal »
John,
Do you have a version of this cabinet that still has the patterns in it? This cab has the file name for the patterns showing, but the patterns do not actually exist within the cab. I may need more info from you. Did all the work/changes to this cab occur directly in the cab/assm editor, or was it pulled from a room/batch and then modified/changed etc.?
JohnLashuay
Hi Scott!
I did create this and place it into a room layout.
-John
Thermwood CS 43
JohnLashuay
Hi Scott!
Here are the patterns that I used for this cabinets.
-John
Rylex Patterns.zip
(5.58 KiB) Downloaded 400 times
Thermwood CS 43
JohnLashuay
I just realized I sent the wrong dwr slide pattern. :oops:
This is the correct one for that cabinet.
-John
Rylex 18 Dwr Slide.zip
(2.05 KiB) Downloaded 382 times
Thermwood CS 43
JohnLashuay
Hi Guys!
I worked with Scott Vaal and it looks like my Mcafee antivirus is conflicting with the program in regards to the hole patterns getting lost.
-John
Thermwood CS 43
