Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
JohnLashuay
Posts: 645 Joined: Mon, Nov 20 2006, 3:39PM
Post
by JohnLashuay » Thu, Jul 08 2010, 11:33AM
This error came up when loading a job into CN just after I clicked OK to next: Drill Shape not used in OptimizeDrillsThisPart
I had to click the ok of the error about 27 times and then it moved on.
Interesting thing is that when I reloaded that cabinet in a batched job this error didn't come up.
Any ideas?
-John
Drill Shape not used in OptimizeDrillsThisPart.JPG (97.08 KiB) Viewed 6788 times
David Egnoski
Posts: 209 Joined: Tue, May 17 2005, 1:05PM
Post
by David Egnoski » Thu, Jul 08 2010, 12:30PM
John,
I encountered this error when I had a 5mm shelf pin hole in a fixed shelf mortise. I removed the extra shelf pin hole and all was good.
Dave Egnoski
Richmond Cabinet & Millwork
JohnLashuay
Post
by JohnLashuay » Fri, Jul 09 2010, 2:48PM
Thanks for the response, but no I don't have a fixed shelf mortise in this cabinet.
-John
Ryan Hochgesang
Post
by Ryan Hochgesang » Tue, Jul 13 2010, 7:46AM
John,
If you could please send the supporting files for this situation to:
program@thermwood.com we will have a look at it. Be sure to reference this posting so we can reply both areas. Files needed:
1.) Export from Control Nesting
2.) eCabinet job or cabinet files (.esj or .hsf)
Thanks!
JohnLashuay
Post
by JohnLashuay » Tue, Jul 13 2010, 9:42AM
HI Ryan!
I modified the cabinet since then and it ran fine without the error.
I'll check to see about sending these to you.
-John
Ryan Hochgesang
Post
by Ryan Hochgesang » Tue, Jul 13 2010, 12:11PM
Thanks for the update!
JohnLashuay
Post
by JohnLashuay » Mon, Jul 19 2010, 10:12PM
Hi Ryan!
Here is a new one that is doing the same thing.
-John
Rylex Error.zip
(4.15 MiB) Downloaded 473 times
JohnLashuay
Post
by JohnLashuay » Tue, Jul 20 2010, 8:55AM
FYI, here is what I found out from the Thermwood guys. This actually isn't an error!
John,
The dialog you are seeing is not really an error. It is informing you that 2 drill holes on reverse sides of a piece are intersecting but are not exactly over each other therefore it cannot drill straight through. It will tell you this for each and every set of holes.
Thanks guys for the help!
-John
