Duplicating a cabinet didn't exactly work out
Post by Donald Thomson »
I've attached a job and a picture of a kitchen I'm working on. I selected the cabinet over top of the range and said duplicate to the left. After going through a bunch of error dialogs it finally finished and gave the results in the picture. Notice the "thing" hanging out the the left of the cabinet that was duplicated. I have not been able to delete this appendage.
I don't think this is normal... :shock:
Cabinet duplicate issue 800x500.jpg (12.51 KiB) Viewed 7433 times
Randy kitchen.zip
(3.74 MiB) Downloaded 423 times
Re: Duplicating a cabinet didn't exactly work out
More information - when I take a cabinet from this job into cabinet editor the appendage is still on the screen. IT'S ALIVE!!!! :shock:
Its alive 800x450.jpg (30.28 KiB) Viewed 7427 times
One more note - the appendage does not go away in presentation mode. It's going to be tough showing this to the client... :(
Thermwood - could you help me get rid of this appendage so I can show my client?
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Here is the fixed file.
Randy kitchen_fixed.zip
(3.81 MiB) Downloaded 431 times
Rick Deskins
Thank you Rick,
What did you have to do to fix this?
I'd like to fix my current working version which has lots of changes since posting the icky file.
Don,
I would post the second job. I bet that fix is not something you can do with just the software.
Rick Deskins
Well, I guess the easiest way to fix it in the current version is too:
1. draw a wall in the job big enough to place 3 cabinets
2. place std base frameless on each end of the wall, then place one in the center of the wall
3. select the center cabinet and choose expand to fill
the appendage should disapper.
4. delete the cabinets and wall you just created.
5. Save the job.
Rick Deskins
Don,
I guess I was wrong :D
Thanks Rick! Worked great.
I'm not even going to try and understand how it worked.
Rick Deskins
I'm glad it worked. This was just a work around. A bug has been found and will be fixed in the next build.
Rick Deskins
