Doors on front and back of cabinets
Anthony Towers
Post by Anthony Towers »
I need to make some uppers that have doors on both sides, have looked for an answer on the form libery but can't find an answer. when I use a regular seed cabinet and remove the back it will not allow me to put doors in place of the back.Is there a way that this can be done. tony
Re: Doors on front and back of cabinets
Here is one way that I do it.
I make up the cab. that I want then copy it then just us the face frame and doors on the back of the first cab.
Test Cab_11-3-10.esa
(562.02 KiB) Downloaded 343 times
Here are some base cabs I did with doors on the back. The "Front Cab" has no back, and the "Back Cab" also has no back and the depth is set at 1/32". In CL, place the cab then rotate it.
Two sided cabs.esj
(1.13 MiB) Downloaded 335 times
