Gary Puckett
Posts: 1324 Joined: Mon, May 19 2008, 1:39PM
Company Name: The Woodworkery
Post
by Gary Puckett » Sat, Jan 22 2011, 4:02PM
I am have a problem with the color white coming out white in a rendering. Has anyone else had this problem?
Scott G Vaal
Posts: 1740 Joined: Tue, May 17 2005, 12:44PM
Post
by Scott G Vaal » Sat, Jan 22 2011, 5:41PM
Gary,
It would be best to give us an example picture of what you are seeing and the job you are working with.
Gary Puckett
Post
by Gary Puckett » Sat, Jan 22 2011, 6:47PM
Scott,
Here is the job and a picture. The Vanity, toilet, and the shower stall all schould be white.
Ipswich Rendering.zip
(440.27 KiB) Downloaded 1077 times
Posts: 563 Joined: Thu, Jun 16 2005, 7:53PM
Post
by Mark McCallum » Sat, Jan 22 2011, 7:04PM
Here is one that it has happened to. It should be all white.
Nev Vanity.esa
(3.4 MiB) Downloaded 1125 times
Post
by Mark McCallum » Tue, Apr 05 2011, 7:33PM
Hi guys
I found a trigger to cause this effect
To recreate this problem I take this corner unit into the door editor,
Highlight both doors.
Select the hole pattern for the hinge cup.
Select a new pattern.
Choose yes to accept to apply to selected doors.
When I return to the Main the colour changes.
(I had a little play with a base cabinet and it definitely seems to be the hinge cup pattern that causes it)
Hope this is useful.
Coloured corner doors.jpg (10.12 KiB) Viewed 13589 times
