Drawer box loosing PE geometry
Post by Donald Thomson »
I've attached a cabinet file along with a couple of dbx files.
The problem I'm having is that when I add the attached 9" dbx to the cabinet, the dbx's PE cuts are going away (the cabinets PE cuts are not effected).
When I add the 4" dbx the dbx's PE cuts are staying in place (again, cabinet PE cuts are not effected).
Any ideas would be greatly appreciated. TIA!
9 inch Drawer box.hsf
(222.02 KiB) Downloaded 385 times
4 inch Drawer box.hsf
(160.02 KiB) Downloaded 431 times
Base 30.5h x 21d - 3 drws.jpg (11.42 KiB) Viewed 7514 times
Base 30.5h x 21d - 3 drws.hsf
(1.13 MiB) Downloaded 416 times
Company Name: Halls Edge Inc
Re: Drawer box loosing PE geometry
Post by Josh Rayburn »
Hi Donald,
Did you do the part editor cuts before or after edgebanding?
It may be worth a try to use a current v6 standard drawer box with edgebanding, then do your part editor work, then add the constraints - and see if that helps...
Thanks Josh.
I didn't think it would matter about the order that I did things to drawer boxes. To add more information to this situation, when I add the 9" dbx's all of the PE cuts are intact. It is only when I add the 4" dbx to the cabinet do the 9" dbx PE cuts disappear. This seems like really odd behavior. I don't understand how adding a dbx could cause other dbx's to be modified.. Another one of the great mysteries of eCabs... :shock:
Thermwood folks - any thoughts on this problem? I have to get started cutting a job soon and need to get this resolved asap.
TIA!!
Don,
I would do as Josh suggests and start from scratch with a current Version 6 Standard drawer box.
Save the new box under a new name.
Another method is to create your hole patterns and save them as KD fasteners then apply KD joinery to your boxes. This eliminates all the constraints.
Thank you Kerry. Where would I find a "V6 drawer box"?
Scott G Vaal
Post by Scott G Vaal »
Donald,
Took me a few minutes of scratching my head, but I have finally figured out why your 4" box had holes and the 9" did not. Your 9" box was saved at 22" deep and the 4" was saved at 20" deep ( 20" is the size needed for the depth of the cabinet). So, when the 9" box gets re-sized to 20" deep, it moves the holes off of the part because they are not constrained thus looking like they are lost (which they kinda are). Also, I did find some troubles with the 9" box that required removing the PE cuts and adding them back on. I have attached both boxes with constraints added and your cab with them installed. Hope this gets you going.
4 inch Drawer box_withCM.hsf
(162.02 KiB) Downloaded 415 times
9 inch Drawer box_withCM.hsf
(188.02 KiB) Downloaded 438 times
Base 30.5h x 21d - 3 drws_sgv1.hsf
(1.16 MiB) Downloaded 420 times
Don,
Using XP mine follow this path
C:\Documents and Settings\All Users\Documents\Thermwood\eCabinet Systems\drawer boxes\standard
You may have started with a V6 box.
I had some problems editing drawer boxes that were in some of my library cabinets created in V5.
Thank you everyone. :beer: :beer:
I ended up remaking the 9" box. When I added boxes back to the cabinet I added the 4" first then the 9" and everything seems to be ok.
A little back ground, I have a 2 monitor system for lots of screen real estate. Makes life easier. Anyway, I also noticed something interesting with the dbx editor. I have the dbx editor open on the right monitor over top of the main eCabs window. When I add constraints to a drawer box and exit the constraint editor and save the changes, the dbx editor jumps to the left monitor completely outside the main eCabs window. Just thought this was interesting and spooky. :?
Scott G Vaal
Don,
I had no problems adding the two 9" boxes first, then the 4" box. Are you saying that you still cannot add the 9's first?
Scott,
I didn't try the other way. All I know is I got it to work and now I'm cutting. :D
Thank you everyone for your help on this. This is such a great resource for help! :beer:
