Cabinet/Assembly Editor causes ecabinets to end
Christopher Hidell
Company Name: Hidell Co LLC
Post by Christopher Hidell »
I create a new cabinet from the standard cabinets and then save it in a job library. When I next open that library and click on that cabinet, it will cause ecabinets to close unexpectedly. This also happens when I am in an existing room layout and want to modify a placed cabinet by opening the editor. Any ideas?
Re: Cabinet/Assembly Editor causes ecabinets to end
Hi Christopher, can post your computer specs.
Christopher Hidell
Hello Rick,
My system is a Dell Precision T3400 with Intel Core 2 Duo CPU, Nvidia Quadro FX 1700.
Christopher
Christopher, is it one cabinet in particular or all from that library? Also check the save path. This is what they should be:
for XP: C:\Documents and Settings\All Users\Documents\Thermwood\eCabinet Systems\cabinets
For Vista/Win7: C:\Users\Public\Documents\Thermwood\eCabinet Systems\cabinets
Can you post the cabinet please.
Christopher Hidell
Rick,
The XP save path matches with the addition of the job name at the end.
It happens for all cabinets all jobs.
I believe I have attached the file, let me know if you cannot load it.
Thank you
3 Dw Base.jpg (23.14 KiB) Viewed 13832 times
That's just the jpeg. It needs to be the HSF file.
Christopher Hidell
Sorry about that. Give this a try.
Christopher
Upper Sink Base Right.hsf
(396.02 KiB) Downloaded 777 times
Christopher,
I am not seeing any problems with this cabinet.
Does the problem still occur after exiting eCabinets, shutting down Windows and re-starting everything?
Christopher Hidell
Hi Kerry,
The problem continues after ecabinets shutdown and/or whole system shutdown. I might get it to work 1 in 10 tries and it seems to be random. I have taken to starting with the standard cabinet each time I start a job, so I do not think it is an ongoing library error.
Could this be some sort of display card error?
The other thought I had was to use the restore settings part of ecabinets.
Christopher
Try a driver update for the graphics card.
Christopher Hidell
Rick / Kerry
I updated the card. I seem to be able to regain the use of the editor in normal fashion. Interestingly, some of the cabinets in the quick test layout I made pre-update will move into editor, but I cannot manipulate them. Other cabinets work fine.
Thank you for the help. I'll see if things are back to normal this coming week.
Christopher
You might want to check the Dell website for any updates also.
