I'm not sure what the problem is, but it seems to happen whenever I change the thickness of the material when creating the TWD output file.
The nesting diagram on my computer is fine, but when I create the TWD output file and then batch it to the machine I am missing cabinets and some cabinets are batched multiple times.
Is this a known glitch?
I'm guessing I can just make a new material with the correct thickness and change everything, but over time the material list is going to be quite large.
Just wondering if anyone else is experiencing this and if the above is the only work around
Batching Problems
Andrew Moura
- Company Name: Andex
- Scott G Vaal
Re: Batching Problems
Andrew,
If you can get us a job file and some steps to reproduce it, then we can see if we can get it to happen here and try to determine the cause.
- Kerry Fullington
Andrew,
I had a similar problem with a job a while back.
I wrote the TWD file from eCabinets and did not change the material thickness. Let's call it Job 1.twd
When I realized that I had forgotten the material thickness change I re-wrote the TWD file but saved it using the same "Job 1.twd" file name. When I opened the twd at the control there was one cabinet that had been reproduced three times and some other cabinets on that same wall were missing.
If I re-wrote the TWD file from eCabinets and gave it a new, unique name then every thing was fine.
- Kerry Fullington
I had this happen again this past Sunday.
I noticed a job went from 19 sheets nested in eCabinets to 25 sheets nested at the control. A tall cabinet had been duplicated five times.
- Kerry Fullington
Download files HERE
Open the job file in ecabinets
Click CNC
Change 3/4" maple material thickness to .730
Change 5/8" maple material thickness to .610
Do nothing to mdf material
Save the .twd as utility_NEST.twd
Open the .twd in control nesting V 5.66
In control nesting I show 7 number 11 tall cabinets. There is only one in the job
Click CNC
