A problem has occurred after updating to Control Nesting V5.66
Under Flip Ops First I select Cut Flip Operations First then Trim Sheet and then select Pin Area Only
When I look at the code it is trimming 3 Sides Not just the pin area
I then notice I can select more than one radio button in the flip ops first dialog
Problem Trimming Flip-Ops First
- Kerry Fullington
Joe Harger
Re: Problem Trimming Flip-Ops First
Kerry, this problem has been reported to the programmers and a fix for it should be available next release...I have talked with Keith as well and let him know.
Joe Harger
Software Support
Thermwood Corporation
Joe Harger
Software Support
- Kerry Fullington
Thanks Joe,
Keith would like to revert back to the previous version of control nesting. Is that possible?
Joe Harger
I have talked with Keith and we have already discussed that and he is going to wait until the release. I will keep in contact with him and if the release takes longer than he likes then I can
help with his previous version.
Joe Harger
Software Support
Joe Harger
Software Support
Wayne Adelkopf
- Company Name: Noble Woodworks Inc.
Kerry,
Curious, why do you trom 3 edges?
- Kerry Fullington
Wayne,
I only want to trim the pin area of two edges but after updating control nesting to version 5.66 that is broken.
If I selected Trim Pin Area only the machine did not trim anything.
