Misaligned Crown molding
Leo Graywacz
Post by Leo Graywacz »
I have a cabinet that when you use the crown editor area won't put the corners of the crown together. The problem happens because I have face frame offsets for the side pc of plywood. This puts the plywood side in from the edge of the cabinet by 3/4". Then there is a panel that is applied on the plywood making it flush the the edge of the FF.
But the return pc of crown stays following the plywood. I can't get this crown to push out and look like it is wrapped around the panel. It is sunk inside it.
I can adjust the scribe of the front pc of crown to make that look correct, but not the return. That only has scribe functions for front and rear.
Am I forced to apply a pc of crown manually there? Or am I missing something?
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Scott G Vaal
Re: Misaligned Crown molding
Post by Scott G Vaal »
Leo,
Can you post the cabinet so I can see the exact situation.
Leo Graywacz
Hope this is it. It's so buried in the file structure of the computer
LO Pantry upper.hsf
(644.02 KiB) Downloaded 751 times
LO Pantry upper.jpg (15.34 KiB) Viewed 8187 times
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Scott G Vaal
Leo,
If you need it for looks, then yes, your best option is a display molding. If you did not need it for looks, it is the correct size already, just positioned over by the face frame scribe.
Leo Graywacz
Ya, it's just for the presentation. I was wondering why my upper rail on the panel looked so fat. I zoomed in and the crown was buried.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
