Sloped Counter
Nat Wheatley
Sloped Counter
Post by Nat Wheatley »
On cabinet with a sloped top, is there a way to have the counter follow the slope? I've attached a screenshot of what I came up with, using the Countertop Editor. Sorry for the extremely basic drawing, I rarely use this area of the software (or the Countertop Editor...) Thanks.
Re: Sloped Counter
Nat,
Instead of using the countertop editor to place your top, create a top using a display cube and associate it to the cabinet in the cabinet editor.
Nat Wheatley
Re: Sloped Counter
Thanks Kerry, I'll give that a try. (No doubt more questions to follow...) -Nat
Nat Wheatley
Re: Sloped Counter
I may not be going about this right, but I brought the display cube and cabinet together into the Cabinet Editor. The screenshot shows as far as I was able to get. My plan was to use the 'Align Items' feature. I was able to select a node on the display cube, but not on the cabinet (trying for the upper corner), for some reason. Not sure why.
Re: Sloped Counter
Nat,
Double click the cabinet to select it and the align tool will work. The cabinet will have a green outline not a hatch pattern. It looks like you have just selected an end.
Nat Wheatley
Re: Sloped Counter
Thanks Kerry, that did it. -Nat
Re: Sloped Counter
Nat,
Be careful playing with the 3D stuff, it can be addicting.
Nat Wheatley
Re: Sloped Counter
Extremely nice work Kerry. I'm continually amazed by what you're able to do with the software
In stark, stark contrast here's where I'm at:
Looks like there's still quite a bit to learn! Thanks again for the help.
Gary Campbell
Re: Sloped Counter
Post by Gary Campbell »
Kerry...
You are a sick individual. :D Teasing me that way! Can my and my little CNC come live with you for the winter?
Gary Campbell
Re: Sloped Counter
Gary,
Since you are in Florida maybe I should come see you.
7 degrees here this morning.
Gary Campbell
Re: Sloped Counter
Kerry...
It is terribly cold here also. The worst and longest cold snap I have seen in 10 years. 41 degrees and a 30 kt sideways rain. I have never seen it that cold either. I wanted to visit you because I thought you had a fireplace!
Gary Campbell
Re: Sloped Counter
Gary,
We have a house in Colorado that has a fireplace. Maybe we should all forget about work and just go there for the winter.
