DennisMeurer
Posts: 1 Joined: Mon, Mar 19 2007, 11:34AM
Post
by DennisMeurer » Mon, May 21 2007, 2:18PM
Was just curious if any one has designed a Island range hood and how it was done
Paul Ellis
Posts: 193 Joined: Tue, Jan 17 2006, 1:27AM
Post
by Paul Ellis » Mon, May 21 2007, 2:28PM
Dennis,
Welcome to the forum. You can do a search for 'range AND hood' and get lots of references. Have a look at this one by George Davidson
http://ntc.thermwood.com/forums/viewtop ... d#img_1868
I am sure George will be glad to help get you on your way in designing one!
Good luck
Paul Ellis
"If it works, don't fix it"
Al Navas
Posts: 443 Joined: Fri, Feb 17 2006, 5:22AM
Post
by Al Navas » Mon, May 21 2007, 2:35PM
Just a quick fix on the URL, Paul:
Enjoy!
Michael Yeargain
Posts: 1740 Joined: Tue, May 17 2005, 8:33PM
Post
by Michael Yeargain » Mon, May 21 2007, 4:48PM
You can also export the file as an HSF and import it into the display part editor and save that as an STL file. With the STL file you can import that into your custom layout and resize as needed.
This will work if you don't plan to do a cut list from the display. If you plan to cut the part then save the new hood as an assembly.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Lamar Horton
Posts: 222 Joined: Sun, Dec 11 2005, 1:22PM
Post
by Lamar Horton » Mon, May 21 2007, 5:28PM
Here is one I did recently. It is some drawer fronts and display panels.
Posts: 1585 Joined: Tue, May 17 2005, 1:16PM
Post
by George Davidson » Mon, May 21 2007, 8:52PM
Hi Dennis
Here is a 30\" and a 36\" Inland hood that you can play with I would keep it
in assemblies (It has alot of parts)
