Lumicor
Lumicor
Anyone have any tips on working with Lumicor? Cutting it is not a problem, it's the fabrication that is. We need to apply it to HPL. The architect has spec'ed 1/4\" Lumicor to be applied over plastic laminate as a decorative feature. The edges need to be bonded together to form corners and the material needs to fastened to the PL in a way not to distort the clarity of the product.
Rick
According to the Lumicor website, you can use normal router bits, etc for working with it.
Thank you Dan. Cuttings not the issue, it's sticking it to the PL that is.
The same site has binding info as well.
Thanks Dan
