Help on Poker Table top
I can make the 4 sides but can not make the other 4 side how can I do it :?: I am makeing a 8 sided poker table for my old night club I have been out of there for 8 years now. The 2 new guys want to put a poker table in the back room :?: I had 7 poker machine in the back room I was there 18 years and they were there when we buy the place. The back room was doing about $30,000 a week.They say it is doing about the same now.
They think that it can do more :?: I tryed to tell them the old people
don't want to play poker they want to play the machine.I don't want to see them do it. I still hold a note on it I am to old to go back into the bar
and night club seen.A lot of over head
New Folder.zip
(1.6 MiB) Downloaded 707 times
Mark Hesketh
Company Name: Paris Kitchens
Post by Mark Hesketh »
Are you talking about creating the chip trays in the other 4 sides? If that is what you are going for, trying taking the top into the part editor, then into contour mode. Right-click and select \"create edges\". You can then use the offset function to copy the lines a specified distance away. Trim them to the shape you want, then exit from contour mode and pocket them away.
Hope this helps
Thank You Mark
I played with it a little I. I got all the out line but could not cut it out.
I have to go out to the shop now. I will play with it later.One thing I have to do today is the cradle it has been sitting for 2 weeks
Thank You Mark
9-30-07 Sunday.JPG (203.78 KiB) Viewed 8025 times
9-30-07 Sunday (2).JPG (207.61 KiB) Viewed 8025 times
Mark Hesketh
No problem George.
To get it to cut out, once you have made your shapes, exit from contour mode, right-click and select \"cut/pocket using closed contour\". then select the shape, it should turn green. in the bottom right corner of the screen a \"next\" button will appear, click on this and it will bring up the dialoge where you select your depth.
hope that gets it to work for ya
:beer:
Michael Yeargain
Post by Michael Yeargain »
George,
You should have been done with that cradle by now. The baby is coming and it ain't gonna wait for the cradle. :o
The poker table: can you import a dxf file to cut the pockets. Is the problem because you can't do angular geometric shapes?
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
I know
Michael it should be in the zip file
Michael Yeargain
What is the overall width of the top suppose to be?
32Gigs DDR4
Corsair RM650
Michael Yeargain
Here George,
Hope this helps. Took me a while but I created a DXF file you can import into the part editor and do all the editor cuts at one time.
new_folder_313.zip
(1.62 MiB) Downloaded 657 times
32Gigs DDR4
Corsair RM650
Thank You Mark and Michael
I can see I have to learn alot more about the part editor.
Michael that looks great
Michael Yeargain
The DFX file is included if you need to produce another top like that one. In fact you can inlarge or srink it to fit any octogonal shape by selecting the shape and using Ctrl and both mouse buttons.
32Gigs DDR4
Corsair RM650
