Rotate Stretcher
Wally Schneeberger
Rotate Stretcher
Post by Wally Schneeberger »
Maybe some one could tell me why I cannot rotate the bottom front stretchers on this cabinet without getting all kinds of errors or reverting back. TIA.
L1.hsf
(1.29 MiB) Downloaded 613 times
Damon Nabors
Re: Rotate Stretcher
Post by Damon Nabors »
Wally, what are you trying to do? flip it over 180deg, stand it up and down, or what?
Damon Nabors
Post by Forrest Chapman »
Wally,
I rotated the front stretcher and saved it with no problems. My process was go to stretcher editor and highlight the part then go to adjust stretcher. At bottom left side of screen use the rotate function and exit back to main editor. Are these your steps?
L1.hsf
(1.3 MiB) Downloaded 614 times
Wally Schneeberger
Damon Nabors wrote:Wally, what are you trying to do? flip it over 180deg, stand it up and down, or what?
Yes I'm trying to rotate 180deg. Every time I do it reverts back to 90deg and changes the insets.
Wally Schneeberger
Forrest Chapman wrote:Wally,
Yes Forrest that's exactly what I tried to do. When I opened your download it was at 78 deg.
Wally,
I set it at an odd angle just as a point but you can put it any way you like. Are you saying you want a left to right stretcher with an front to back orientation? If so just add it that way.
Damon Nabors
Wally,
The reason I asked if you are trying to rotate it 180 or whatever, was because I had a hunch that you are trying to get the tenon on the back side of the stretcher, rather than on the front. Rotating the stretcher will create problems. What you need to do is: go into the stretcher editor and then click on the stretcher ( turns green w/hash marks), now go up to the top and click construction settings, then go to the construction parameters (left/right -up / down) when you get into the construction parameters, change the tenon bottom side/tenon top side radio button. This will reverse the tenon and everything will work the way you want it to. That is if I understood what you are after. Here is a picture exploded with the tenon switch on the left stretcher.
Damon Nabors
Wally Schneeberger
Thanks Damon .... That's exactly what I was after and it worked great. I learned another lesson tonight.
