Test: place the door with the fewest keystrokes
Gene Davis
Post by Gene Davis »
A frameless blind basecab is the today's challenge cup, and the file is attached.
The door has a 1/8" margin between itself and it's "stile" on the left, which is the spec for the Blum blind corner hinges used there.
Bottom reveal is zero, top reveal is 3/8", R side reveal is 1/8".
Take the cabinet, remove the door, and replace it so that you get the same reveals. It is a "faceframed" cab, with the only part of the faceframe being the 4" "stile" the door is hinged to, thus the door is inset 3/4".
I'll start the timer when you've loaded the file.
LH blind base.hsf
(454.02 KiB) Downloaded 372 times
Re: Test: place the door with the fewest keystrokes
Gene,
What seems to be the problem? Once you save your file with the door parameters there is no problem changing doors.
Gene Davis
Load it up and go to work, Kerry.
Let's see what you need to do to get the job done.
I did it before the last post.
3/4 inset
+1/8" Hinge side gap
-5/8" Open side gap
-3/8" Top gap
-3/4" bottom gap
I still don't know what you are trying to get at.
Damon Nabors
Post by Damon Nabors »
Not sure what the problem is, changed doors for ya
iiii.hsf
(400.02 KiB) Downloaded 399 times
Damon Nabors
Glenn Warner
Post by Glenn Warner »
Took about 5 minutes because I didn't get the constructions settings on the first try.
Hinge side gap: -.75"
Open side gap: .125"
Top gap: -.375"
Bottom gap: -.75"
Door inset: .75
Good practice. Thanks
Glenn
Damon Nabors
What happened to Gene, did his timer break?
Damon Nabors
