Bead Board
Gary Puckett
Company Name: The Woodworkery
Bead Board
Post by Gary Puckett »
Does anybody have an image of Bead Board ?
Vince Lisanti
Re: Bead Board
Post by Vince Lisanti »
Gary,
Here are a few I use .
I just create a sheet material using these images.
Vince
CCS woodworks inc.
beadboard cream.jpg (23.85 KiB) Viewed 6775 times
beadboard antique white.jpg (52.67 KiB) Viewed 6779 times
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
Gary Puckett
Re: Bead Board
Vince,
Thanks, I copied the picture and when I went to add a new image in the material section no image came up. Any ideas why no image came up?
Wally Schneeberger
Re: Bead Board
Post by Wally Schneeberger »
You have to put it in your image file under a heading like IMPORTS.
Gary Puckett
Re: Bead Board
I did I called it Bead Board
Vince Lisanti
Re: Bead Board
Gary,
I am not sure why the images will not show up for you ?
The only thing I can suggest is to add the images to your material folder with e-cabs shut down and see if that works.
Find your ecabs folder than your materials folder add a new folder in there called beadboards, open this folder and copy and paste the beadboard images to this folder.
Close down your folders and fire up ecabs. Settings/Preferences, Define Stock Materials, Sheet Stock , Select Image, Beadbords, (You created this folder earlier) The beadboard images should now be in here.
Good Luck
Vince
CCS
32 GB RAM
