Help!!! E-Cabs won't open
ScotAcree
Company Name: Scot Acree Woodworkig LLC
Post by ScotAcree »
Have been using Windows Vista Business for over a year with absolutely no problems.
This morning, I could not open it.All I get is,"E-Cabinet Systems Application has stopped working."I was right in the middle of a bid,so where do I start?
Scot
Todd Miller
Re: Help!!! E-Cabs won't open
Post by Todd Miller »
Try downloading the new update and install it. Here is the link.
http://downloads.thermwood.com/eCabinet ... uild-2.exe
ScotAcree
Post by ScotAcree »
Todd,
No luck.Wizzard downloaded and installed it,but I get the same message.
Scot
Todd Miller
What version of ecabs were you running before this problem occured?
First, run the update again. If that doesn't work you may try to uninstall and reinstall. I will send you a new reg code.
NOTE: Be sure to backup your files.
ScotAcree
Post by ScotAcree »
Todd,
I was running the 5.2 - 1
Also,I received the new code.
Scot
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
You need to make sure you run the patch as a administrator.
http://ntc.thermwood.com/forums/viewtop ... f=3&t=6523
    Rick Deskins
    ScotAcree
    Post by ScotAcree »
    I am still having problems with :wall: running the software. Here is the procedure that I used:
    1. Installed ecabinets by running from the cd. I ran setup.exe by right-clicking on setup.exe and choosing runas Administrator.
    2. The install completed successfully. I then downloaded the build 2 patch. At this point, I am having a strange problem. If I right-click on the build2 executable, and select runas Administrator, it only gives me the option to remove build 2 even if I have not yet installed it. If I select Remove it does indeed uninstall build 2. So, instead I right-click and select properties for the build2.exe and selected the run as Administrator option from the properties. Then I just double-click the build2 executable and it installs build 2 without any errors.
    At this point, everything seems to have installed OK. Also, on the ecabinets shortcut, it does have the shield, implying that it is being run as Administrator. I checked the properties to confirm this. Once I run ecabinets though, it shows the ecabinets splash screen and then fails during startup. I have included the screen capture of the message that occurs during startup, although that is unlikely very helpful. There were also 2 events added to the event viewer of which I have also attached screen captures. Hopefully these shall be of some help. The event 1001 message was too long for a screen capture, so here is the pasted text from the dialog window containing the message:
    Fault bucket 808526717, type 1
    Event Name: APPCRASH
    Response: None
    Cab Id: 0
    Problem signature:
    P1: ECABINETS.exe
    P2: 5.2.18.0
    P3: 4856b3a4
    P4: nvoglv32.dll
    P5: 7.15.10.9746
    P6: 4578ec00
    P7: c0000005
    P8: 00236a3d
    P9:
    P10:
    C:\Users\sacree\AppData\Local\Temp\WERA7B4.tmp.version.txt
    These files may be available here:
    C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Report10751880
    Thanks for any help, Scot Acree
    Event Error 2
    Event Error 2
    First Event Error
    First Event Error
    Splash Screen Error Message
    ScotAcree
    Post by ScotAcree »
    Are there any other Vistas users having problems right now???
    Or,has anyone installed the new build with Vista with success??
    Scot
    ScotAcree
    Post by ScotAcree »
    OK, I resolved the problem. Hope this information can help someone else. I followed the following procedure to install ecabinets on vista:
    1. I installed from the CD]by right-clicking setup.exe and selecting run as Administrator. I then ran through the default installation process. It finished with success.
    2. I downloaded the build 2 executable. I right clicked on it and selected run as Administrator. It starts running through the installation wizard, but rather than allowing me to install the build 2 update, it wants to remove it. So, I went ahead and let it remove the build 2 patch even though it was not yet installed. This finishes with no problem.
    3. Upon completion of step 2, I then right click on the build 2 patch executable again and select run as Administrator. This time, I can go through the the build 2 wizard and install build 2. Everything finishes and I am now able to run ecabinets as expected.
    Scot
