Double sided cabinets
Post by Forrest Chapman »
It would be great if Thermwood added a few double sided seed cabinets and the ability to work from either side. I need to build some island bases for closets with drawers in both sides.
Fortunatly they are a standard and only have to be created once. Part editor has become my best friend.
Dale Wills
Company Name: none
Country: AUSTRALIA
Re: Double sided cabinets
Post by Dale Wills »
Forrest,
I'm in a similar situation at the moment. I want to created a cabinet that has a door on the front and also a door on the left hand side (to replace left end). I tried to import a second cabinet with the correct size door I wanted and then remove all parts except for the door. But as soon as I removed both ends I lose the door. I think its going to have be a part mod to add the hinges. Any ideas?
Dale
Hi Dale
I call this my work around
I make my cabinet 24 x 34.5 x 0
R & S 1/16" by 1/16"(no overlap)
Hi Forrest
Here is something you can play with
Here is a work bench I made up about a year an 1/2 ago
I made it with Stretchers
It can be resized
My work top can not be resized
Work Benchs.zip
(667.02 KiB) Downloaded 387 times
30 x 36 x 24 2 Sided Drawer Cab.jpg (92.67 KiB) Viewed 4898 times
48 x 36 x 24 2 Sided drawer Cab.jpg (102.99 KiB) Viewed 4898 times
Jeremy Schiffer
Post by Jeremy Schiffer »
Hey guys,
You can load a cabinet into the editor and remove everything, and yes the door will disappear, leaving a blank screen. But the "cabinet" is still there, and it is the size specified in the dimension boxes. Set all your overlays/insets so that the size you specify is the size of door that you want, go to the door/drawer editor, and click in the middle of the screen. The green highlight will light up, and you can add a door ... end result: a cabinet that is simply a resizable door.
I know this doesn't exactly help you Forrest, but I think this is what George is after.
CS-41 4x8
CS-45 5x12
