How do you miter Enkeboll molding
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
Can you miter molding from Enkeboll and if you can how do you do it?
I thought I could just take it to the part editor but it does not support it.
Is this something that the system can't do, or am I missing something.
Todd Miller
Re: How do you miter Enkeboll molding
Post by Todd Miller »
Gary,
Usually if the molding is in the software already, you can select the molding in the "load items" screen. Then set the length and the mitre angles for each end.
Gary Puckett
Todd,
This molding is one you have to convert to a stl file
Hi Gary Could you show me the Molding from Enkeboll
Todd Miller
Gary,
Post the stl file and we can take a look at it. But I am pretty sure you are going to need to mitre the edges and set the length before you bring it into eCabs.
Gary Puckett
Here is the molding
mld-la1.stl
(1.18 MiB) Downloaded 321 times
Gary Puckett
George Davidson wrote:Hi Gary Could you show me the Molding from Enkeboll
George here is the molding right above this post. I think what you have to do is miter it in another cad program then bring it to eCab. I am not that experienced with cad progams to do that. I can just convert dwg and dxf files to stl sometimes :lol:
Try this or giveme the sizes you need
I did not try to resize :beer:
Trim 1-7-08.stl
(758.48 KiB) Downloaded 309 times
Gary Puckett
Thanks George,
It will scale to any size but the shorter you go the 45 degree miter changes. I think if you check the box in the scaling box it looks like it doesn't affect it.
I have intellicad could you tell me the steps to create this miter so I can do it in the future.
Try this DWG File
Trim 1-7-08.zip
(65.71 KiB) Downloaded 298 times
Gary Puckett
No that didn't work. I must have been half asleep last night because when I check the box it did nothing.
