The CabinetShop Series combines all the elements needed for a custom cabinet shop to design and machine custom cabinets, custom furniture and support products. |
Click Here to View the CabinetShop 43 Brochure in Adobe .pdf format
CabinetShop 45 Dimensions
Click Here to View the CabinetShop Series Brochure in Adobe .pdf format
The Multi-Purpose Three Axis Series are highly flexible, making them ideal for a variety of manufacturing applications. |
Multi-Purpose 43 Accent Colors The Multi-Purpose 43 is available with any of five accent colors on the transparent tooling shield and control side panel. A sheet metal control side panel (in painted machine color) is also available in place of the accent colored control side panel.
Click Here to View the Multi-Purpose Series Brochure in Adobe .pdf format
The FrameBuilder Series combine all the elements needed to machine nested upholstered frame parts from sheet stock. |
Click Here to View the FrameBuilder 53 Brochure in Adobe .pdf format
The CarvingShop Series combines all the elements needed to program and run three dimensional wood
carvings. |
Click Here to View the CarvingShop Series Brochure in Adobe .pdf format
The SignRouter Series - This I-Cut compatible system trims printed graphics on rigid substrates such as foam board, plastic, acrylic, fiberglass/composites, wood and non-ferrous metals. It also machines store fixtures made from materials such as wood, plywood, MDF, chipcore, plastic, acrylic and non-ferrous metals. |
Click Here to View the SignRouter 43 Brochure in Adobe .pdf format Click Here to View the SignRouter 43 Flyer in Adobe .pdf format
