Better Machines with More Features and Better Support
**Please Click the Headings Below for more information**
Better Machines (this means better performance, more reliability and longer life)
High-Performance, Highly Reliable Siemens Drives (normally only on much more expensive machines)
Full Function, High Performance CNC Control (compared to limited, bottom end controls)
Designed using State of the Art ProEngineer CAD/CAM (assures best possible structure and performance)
Weldments Fully Stress Relieved (eliminates stress warping and cracking down the road)
Three-Dimensional Laser Compensated (machine is dead accurate everywhere – others can’t do this)
More Features (means more productivity and greater throughput
- Control Nesting (nesting at the control is easier and more productive)
- Free High-End Cabinet Design Software (eCabinet Systems is an industry leading software package)
- QuickCut - Select nested based products from a library at the machine control, resize and cut without the need for external computers or design software – the easiest way to make nested based products.
- Extensive Software Compatibility (control accepts output and can even combine files from a wide variety of design software including ProE, Catia, CabinetVision, eCabinet Systems, KCDw, AutoCAD DXF, etc.)
- Virtual Service (address any problem from configuration to programming by connecting the control directly to service – fast and really easy)
- Automatic Tool Management (manages tooling and tool life – not easy without this feature)
- Maintenance Tracking (manages lubrication and routine maintenance based on actual machine use)
- Error Reporting (graphically displays location of error and suggests remedy – with others finding and fixing is a nightmare)
- Maintenance Videos (on-screen videos guide you through adjustment and repair)
- Dynamic CAD Drawings (view and explode every machine assembly on the control screen for maintenance and part identification)
- Dynamic On Screen Manuals (view and search the machine manual right on the control screen)
Better Support (help when you need it)
The bottom line: Thermwood systems install fast, start up quick, are easier to use and maintain, produce more and last longer.
Printable Version of this page
