Mark Hesketh
Posts: 366 Joined: Fri, Aug 25 2006, 9:12AM
Company Name: Paris Kitchens
Post
by Mark Hesketh » Mon, Jun 11 2007, 7:55AM
when we make our upper corner cabinets, we make it with a 1/2\" back, inset 1/4\", with the back full-dadoed into the top and bottom, as well as the gables. is there a way so that the top, bottom, and gables could have this dado cut for the back right to the edge of the material? right now it leaves a 1/4\" strip on the outside, which makes it a pain for the guys to assemble the cabinet. the only way i can think of is to create a cabinet with a 3/4\" back with no inset, and not cut the backs, then create a second cabinet and only cut the 1/2\" backs from that.
i have tried taking the parts into the part editor and creating a pocket to cut away the material, but it comes up with an error every time.
any suggestions would be welcome!
Posts: 5852 Joined: Thu, Jul 28 2005, 10:18AM
Post
by DanEpps » Mon, Jun 11 2007, 8:06AM
You can use blind dado and set the thickness to 150% of material thickness (in back construction parameters).
It leaves a funny looking lip on the sides of the back but the dado is correct.
Post
by DanEpps » Mon, Jun 11 2007, 8:07AM
Oh...you will also have to set all of the tenon placement values to 0\".
Mark Hesketh
Post
by Mark Hesketh » Mon, Jun 11 2007, 8:07AM
Thanks Dan, I will give that a shot.
... it's not going to give me any issues at the machine, is it?
Post
by DanEpps » Mon, Jun 11 2007, 8:12AM
I couldn't tell you whether it will create any CNC issues. I wouldn't think so since the back is 1/2\" material. Just double check the CNC code to see before machining it.
Mark Hesketh
Post
by Mark Hesketh » Mon, Jun 11 2007, 8:32AM
k. thanks again
Mark Hesketh
Post
by Mark Hesketh » Mon, Jun 11 2007, 9:32AM
ok, if the nesting within ecabinets is any indication. this won't machine well at all. here are some screen captures of how the material nests. note the dado (?) across the top and bottom of the unit, and the backs are completely screwed... the holes start wayy off the sheet, etc.
corner 3quarter.JPG (100.4 KiB) Viewed 9705 times
corner half.JPG (93.54 KiB) Viewed 9705 times
Mark Hesketh
Post
oh, and here are my settings for the backs
corner settings2.JPG (138.54 KiB) Viewed 9704 times
corner settings1.JPG (119.31 KiB) Viewed 9704 times
Post
by DanEpps » Mon, Jun 11 2007, 10:45AM
I had all of the tenon placements at 0\" instead of -1/2\". I don't know whether that will make any difference or not at the machine though.
Mark Hesketh
Post
by Mark Hesketh » Mon, Jun 11 2007, 12:30PM
tried setting them to zero, still get some funking looking nest layouts... and it also leaves the dadoes in the gables a little short
Post
by DanEpps » Mon, Jun 11 2007, 12:44PM
I think you are probably stuck with using 3/4 material for the backs.
Hey, you can create a 3/4 material and name it something like \"This is really 1/2\" back\"
Mark Hesketh
Post
by Mark Hesketh » Mon, Jun 11 2007, 1:53PM
yeah, that's more or less what I am setting up now. one of the drawbacks though is that they won't nest with the rest of the 1/2\" backs. oh well.
