Pocketing Problem
- Kerry Fullington
Pocketing Problem
These are some adjustable shelves that I did a through pocket cut (using Closed Contour) in the eCabinets part editor.
I want to cut them out, not turn them to dust.
I have tried changing the Pocket Area (Through Cuts) setting in Control Nesting (down to 1^2) but it still wants to make dust out of the centers.
What am I setting wrong?
- Josh Rayburn
Re: Pocketing Problem
Kerry can you post the job or export file?
- Michael RA Greschuk
Hi Kerry,
Just a shot in the dark here,but isn't there supposed to be a inch " mark beside the 1
(1"^2)
(1"^2)
Joe Harger
Kerry, if you haven't already found problem, post export file and I can take a look at it for you..
Joe Harger
Software Support
Thermwood Corporation
Joe Harger
Software Support
- Kerry Fullington
Josh, I have attached the .twd file I am trying this using the latest Control Nesting Update on thermwood desktop. I would like to get this worked out before I cut this job Sunday.
Michael, I did have the " mark. Just a typo on the post.
- Cut Batch_01_02.zip
- (597 Bytes) Downloaded 967 times
- Kerry Fullington
Joe, Josh,
Here is the export file
- ControlNest5-69.zip
- (243.74 KiB) Downloaded 966 times
- Josh Rayburn
Kerry, there was no .twd file there, just the .dat file.
Kerry, I think you have to set your desired tool to pocket and Rout/Dado.
- Josh Rayburn
Kerry you can also use a "interior" or "exterior" tool and a profile to get what you need if you can't make the pocketing work. I'm sure you already thought of this though....
Joe Harger
Kerry, after looking into file it seems you are wanting to cut a lip, maybe for a glass shelf....Control nesting does not support this type of cut yet...It should see a pocket cut inside a pocket cut, but as of right now it is wanting to pocket the whole area to the .25 lip depth and then do a through cut ...it should cut correctly but with the unnecessary full pocket routine.
Joe Harger
Software Support
Joe Harger
Software Support
- Kerry Fullington
Thanks Joe,
I am going to use Josh's suggestion and pocket the center then use a profile to cut my rebate.
Thanks to all who replied.
Sean O' Hare
I hope you got it cut , Kerry. What I do there is make the thro cut as 1 pocket, then offset the rebate .1mm out from it. Works fine.
sean
- Kerry Fullington
Sean,
I got them cut fine. I was even able to add a pass with a 3/16" tool to square the corners.(and after, decided I didn't like plywood so I tossed them and built the shelf frames out of hardwood)
I didn't think about adding a little space to create two separate pockets. Thanks for the information.
