- CabinetShop
- Multi-Purpose
- FrameBuilder
- CarvingShop
- SignRouter
- Quote Request
The CabinetShop Series combines all the elements needed for a custom cabinet shop to design and machine custom cabinets, custom furniture and support products.
CLICK FOR MORE INFORMATION |
- Tech Specs
- Dimensions
- Brochure
- Appearance
- Performance
Construction: |
Interlocked Engineered Structural Steel - Fully Stress Relieved
Table Size(s): |
61” x 121” Fixed w/Automatic Sheet Location Stops |
5' × 20' Fixed w/ Automatic Sheet Location Stops |
Vacuum: |
Universal Vacuum 1 or 2 Zone
Spindle HP: |
10 HP HSD Spindle (3,000-24,000 RPM)
Tool Changer: |
11 Position Automatic Tool Changer |
Tool Length Measurement: |
Automatic Tool Length Measurement |
Servo Drives: |
Siemens Intelligent Servo Drives Throughout |
Axis Alignment Verification: |
Three-Dimensional Laser Compensated |
Control: |
Thermwood Gen2 SuperControl
Job Level Compatible with 20-20 Technologies, Cabinetvision, Cabinetware, KCD Software, Microvellum and eCabinet Systems |
 Tool Management |
 Maintenance Tracking |
 Virtual Service Compatible |
CabinetShop 43 Dimensions
Click Here to View the CabinetShop 43 Brochure in Adobe .pdf format
CabinetShop 43 Accent Colors
The CabinetShop 43 is available with any of five accent colors on the transparent tooling shield and control side panel. A sheet metal control side panel (in painted machine color) is also available in place of the accent colored control side panel. |
Ruby Red |
Copper Gray |
Cobalt Blue |
Tech Orange |
Green Glass |
CabinetShop 43 Performance Videos
The CabinetShop 43 offers premium performance not normally seen at this price point. For example, it has positioning speeds to 3,180 inches per minute and programmed cutting speeds to 2,250 Inches per minute. The actual speed at which you can cut is determined more by tooling and material than by the machine, but its speed is indicative of the overall solid CNC performance of the CabinetShop 43.
Here are some videos showing this amazing performance: |
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Construction: |
Table Size: |
5x10, 5x12, 6x12, 7x12 Fixed w/Auto Sheet Location Stops |
Vacuum: |
Spindle HP: |
Tool Changer: |
4 Position Bar Style Tool Changer (At the Head Typewriter Changer Available) |
Servo Drives: |
Control: |
 Tool Management |
CabinetShop 45 Dimensions
Click Here to View the CabinetShop Series Brochure in Adobe .pdf format
- Tech Specs
- Dimensions
- Brochure
Construction: |
Table Size: |
5×10 (1.52 meters × 3 meters), 7×12 (2.1 × 3.6 meters), 7×20 (2.1meters × 6 meters) |
Vacuum: |
Spindle HP: |
Tool Changer: |
14 Position Bar Style Tool Changer (At the Head Typewriter Changer Available) |
Servo Drives: |
Control: |
 Tool Management |
CabinetShop MTR Dimensions
The Multi-Purpose Three Axis Series are highly flexible, making them ideal for a variety of manufacturing applications. |
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
4×8, 5×5, 5×8, 5×10, 5×12, 7×10, 7×12 |
Spindle HP |
10 HP HSD Spindle (3,000-24,000 RPM) |
Multi-Purpose 40 Dimensions
- Tech Specs
- Dimensions
- Brochure
Table Size(s) |
Single Table: 10×5
Dual Tables: 5×5, 5×8, 5×10, 5×12 |
Spindle HP |
Multi-Purpose 42 Dimensions
- Tech Specs
- Dimensions
- Appearance
Construction: |
Table Size: |
Vacuum: |
Spindle HP: |
Tool Changer: |
Servo Drives: |
Control: |
 Tool Management |
MultiPurpose 43 Dimensions
Multi-Purpose 43 Accent Colors
The Multi-Purpose 43 is available with any of five accent colors on the transparent tooling shield and control side panel. A sheet metal control side panel (in painted machine color) is also available in place of the accent colored control side panel.
Ruby Red |
Copper Gray |
Cobalt Blue |
Tech Orange |
Green Glass |
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
5×10, 5×12, 6×12, 7×12 |
Spindle HP |
Multi-Purpose 45 Dimensions
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
5×10, 5×12, 5×16, 5×20 (Dual Table) |
Spindle HP |
Multi-Purpose 53 Dimensions
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
5×20, 5×40
(5×10 and 5×20 base extensions available) |
Spindle HP |
Multi-Purpose 63 Dimensions
- Tech Specs
- Dimensions
- Brochure
Table Size(s) |
5×10 (3 meters), 7×12 (3.6 meters) |
Spindle HP |
Multi-Purpose MTR Dimensions
The FrameBuilder Series combine all the elements needed to machine nested upholstered frame parts from sheet stock. |
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
5×10, 5×12, 5×16, 5×20 |
Spindle HP |
18 HP HSD Spindle (3,000-24,000 RPM) |
Optional |
Optional At-the-Head Typewriter Style Tool Changer Available
Roller Hold Down - Optional Automatic Load and Unload Available |
FrameBuilder 53 Dimensions
The CarvingShop Series combines all the elements needed to program and run three dimensional wood
carvings. |
- Tech Specs
- Dimensions
- Brochure
Table Size(s) |
5×10 (More table sizes available) |
Spindle HP |
Multiple 10 HP HSD Spindle (3,000-24,000 RPM) |
CarvingShop 83 Dimensions
- Tech Specs
- Dimensions
- Multimedia
- Brochure
Table Size(s) |
14×56 |
Spindle HP |
CarvingShop 80 Dimensions
The SignRouter Series - This I-Cut compatible system trims printed graphics on rigid substrates such as foam board, plastic, acrylic, fiberglass/composites, wood and non-ferrous metals. It also machines store fixtures made from materials such as wood, plywood, MDF, chipcore, plastic, acrylic and non-ferrous metals. |
- Tech Specs
- Dimensions
- Brochure
Table Size(s) |
Spindle HP |
Table Size(s) |
Spindle HP |
