COMPOSITES - AEROSPACE - PLASTIC TRIMMING - NON-FERROUS METALS
Heavy-duty 5-axis CNC router for aerospace and composite applications utilizing large and heavy fixtures
The Model 70 is a heavy-duty, moving gantry 5-axis CNC router designed for demanding aerospace and composite applications.
Engineered to handle large, heavy fixtures and machine complex aerospace components with high precision and reliability.
Available table sizes up to 10'x20' and an extended Z-axis option up to 60 inches accommodate oversized molds, patterns, and composite parts.
Powered by the Thermwood SuperControl and three-dimensional laser compensated axis alignment for the highest level of accuracy on complex 5-axis tool paths.
Designed for aerospace and composite applications utilizing large and heavy fixtures. Available Table Sizes: 10'x5', 10'x10', 10'x15', 10'x20'
The Thermwood Model 70 is a heavy-duty five-axis CNC router designed specifically for aerospace and composite applications utilizing large and heavy fixtures. It is used for machining complex aerospace components, composite parts, molds, patterns, plastic trimming, and non-ferrous metal fabrication.
The Model 70 is available in four table sizes: 10'x5', 10'x10', 10'x15', and 10'x20'. All configurations feature a 1.5 inch thick solid aluminum table capable of supporting large and heavy aerospace fixtures.
The Model 70 comes standard with a 12 HP 24,000 RPM router with a 4 position automatic tool changing system. An optional 16 HP 24,000 RPM router with a 4 position bar style automatic tool changer is also available for more demanding machining applications.
The Thermwood Model 70 offers an optional extended Z axis of up to 60 inches, providing exceptional clearance for machining very tall composite parts, large molds, aerospace tooling, and oversized fixtures.
The Model 70 comes standard with a 4 position automatic tool changing system. Optional configurations include a 10 or 12 position rotary automatic tool changer for greater tooling capacity and reduced manual tool changes during complex machining operations.
The Model 70 is built specifically for aerospace and composite applications with several key features: an impact resistant five-axis head for durability in demanding environments, a 1.5 inch thick solid aluminum table capable of supporting large and heavy fixtures, three-dimensional laser compensated axis alignment for the highest level of accuracy, an optional machine enclosure, and an optional 5-axis chip collection hood. These features combined with table sizes up to 10'x20' and an optional extended Z axis of up to 60 inches make it well suited for large aerospace component machining.
The Model 70 is used primarily in aerospace, composite fabrication, military and defense, automotive, marine, and industrial pattern and mold making applications requiring large-format five-axis machining with heavy fixture support.
