UPHOLSTERED FRAMES - HIGH-THROUGHPUT - MDF - PLYWOOD - NESTED BASED
Designed for the routing and stack machining of large sheet material such as fiberboard (MDF), particleboard and plywood
The Roller Hold Down Series are high-performance systems for routing and stack machining large sheets of plywood, MDF, and particleboard.
A standard roller hold-down system securely clamps stacked sheets, allowing for high-volume production of identical parts in a single run.
Comes standard with a powerful 18 HP spindle, ensuring it can handle demanding cuts in tough materials with speed and ease.
Can be equipped with an optional automatic load/unload system and lift table for continuous, unattended operation and maximum throughput.
Complete three axis CNC routing system to machine nested upholstered frame parts from sheet stock. The moving gantry, fixed table with roller hold down system is designed for routing and stack machining.
Available Table Sizes: 5'x10', 5'x12', 5'x16', 5'x20'
A complete three-axis CNC routing system to machine nested upholstered frame parts from 4'x8' sheet stock. This moving gantry, fixed table with roller hold down system is designed for routing and stack machining and includes an automatic load/unload system.
Available Table Size: 4'x8'
