PLASTIC TRIMMING - PATTERNS - MOLDS - NON-FERROUS METALS
MODEL 67
Versatile five axis available with either single or dual moving aluminum tables
Featured Video
Thermwood Model 67 Large Sculptures at John Cox's Creature Workshop ▶
Precision 5-Axis Machining
The Model 67 is a versatile 5-axis system designed for trimming complex parts, creating patterns, and machining molds.
Complex 3D Parts
The 5-axis head allows for intricate trimming and machining of highly detailed 3D parts and molds with exceptional precision.
Dual Table Throughput
Optional dual moving tables allow for continuous operation—load and unload one table while the machine works on the other.
Highly Customizable
Tailor the machine to your needs with options like extended Z-axis, various spindles, and multiple tool changing systems.
MODEL 67
Versatile five axis available with either single or dual moving aluminum tables.
Available Table Sizes:
Single Table - 5'x'5, 5'x10', 10'x5', 5'x12', and 7'x10'
Dual Tables - 5'x5', 5'x10' and 5'x12'
Standard Features
  • 12 HP 24,000 RPM Router
  • Intelligent Servo Drives Throughout
  • Thermwood SuperControl
Available Options
  • 6 Position Bar Style Automatic Tool Changer
  • 16 HP 24,000 RPM Router
  • 7.5 HP and 10 HP Dual End Spindles
  • Gridded or Multi-Function Vacuum Tables
  • Extended Z-Axis (36" or 48")
  • Automatic Tool Length Measurement
  • Automatic Lubrication System
  • Gantry Lighting System
  • Continuous C Axis
Model 67 Frequently Asked Questions
What is the Thermwood Model 67 CNC router used for?
The Thermwood Model 67 is a versatile five-axis CNC router designed for plastic trimming, pattern making, mold machining, and non-ferrous metal machining. Its five-axis capability allows for intricate trimming and machining of highly detailed three dimensional parts and molds with exceptional precision.
What table configurations are available for the Thermwood Model 67?
The Model 67 is available in single table configurations of 5'x5', 5'x10', 10'x5', 5'x12', and 7'x10', and dual table configurations of 5'x5', 5'x10', and 5'x12'. All configurations feature moving aluminum tables.
What spindle options are available on the Thermwood Model 67?
The Model 67 comes standard with a 12 HP 24,000 RPM router. Optional spindle configurations include a 16 HP 24,000 RPM router and 7.5 HP and 10 HP dual end spindles for applications requiring simultaneous machining from both ends.
What Z-axis options are available on the Thermwood Model 67?
The Thermwood Model 67 offers optional extended Z-axis configurations of 36 inches or 48 inches, providing additional clearance for machining tall three dimensional parts, large molds, and complex sculptures.
Can the Thermwood Model 67 run dual tables for continuous production?
Yes. The Model 67 is available with optional dual moving aluminum tables. The dual table configuration allows operators to load and unload one table while the machine continues working on the other, virtually eliminating downtime and maximizing throughput.
What is the Continuous C Axis option on the Thermwood Model 67?
The Continuous C Axis is an optional feature on the Model 67 that allows the machine to rotate continuously around the vertical axis without mechanical stops. This enables machining of complex wraparound geometries and cylindrical parts that would otherwise require repositioning.
What industries use the Thermwood Model 67?
The Model 67 is used across industries requiring precision five-axis machining including plastic trimming and fabrication, composite fabrication, pattern and mold making, aerospace, automotive, marine, entertainment and prop making, medical, and non-ferrous metal machining.
