PLASTIC SHEETS - SOLID SURFACE - NON-FERROUS - NESTED BASED - COMPOSITES
MODEL 45
Heavy-Duty 3-Axis CNC Router for high-performance nested-based production
Featured Videos
Traco Manufacturing and Their Thermwood Model 45s ▶
Traco Manufacturing Talks About Their Eight Thermwood Model 45 CNC Routers
Thermwood Model 45 machining a 1.75 inch thick composite panel ▶
Thermwood Model 45 machining a 1.75" thick composite panel
Model 45 5'x10' CNC Machining an Aluminum Sign ▶
Heavy-Duty Flexibility
The Model 45 is a robust platform that can be configured for a huge variety of demanding applications.
Advanced Materials
Designed from the ground up to machine composites, tooling boards, aluminum, and plastics with precision and reliability.
Configurable Power
Available with single or dual spindles up to 18 HP, an optional rotary axis, and tool changers to match your exact production needs.
Proven Reliability
Built on a heavy-duty, stress-relieved steel frame and powered by the legendary Thermwood SuperControl for years of dependable service.
MODEL 45
Heavy-duty three axis designed for composites, tooling boards, plastics, aluminum, cabinets, wood and nested base panels. Available in either single or dual spindles with optional rotary axis. Available Table Sizes: 5'x'5, 5'x10', 5'x12', 6'x12' and 7'x12'
Core Performance
  • 12 HP HSD Spindle (3,000-24,000 RPM). Optional 18 HP
  • Fixed Steel High Flow Table with Moving Gantry
  • 4 Position Bar Style Automatic Tool Changer
Automation & Efficiency
  • Optional Rotary Axis
  • Aggregate Tooling Options
  • 9 Position Drill Bank
  • 5 Position At-The-Head Tool Changer
  • 7 Position Bar Style Automatic Tool Changer
  • At the Head Automatic Tool Changer
  • Rotary Axis (accepts stock from 8" diameter up to 56" in length)
  • Multi-Function Table (pod system capable)
  • Extended Z Clearance and Stroke
Precision & Control
  • Intelligent Servo Drives Throughout
  • Thermwood SuperControl
Support & Training
Model 45 Frequently Asked Questions
What is the Thermwood Model 45 CNC router used for?
The Thermwood Model 45 is a heavy-duty three-axis CNC router designed for machining composites, tooling boards, plastics, aluminum, cabinets, wood, and nested base panels. It is used across industries including aerospace, marine, furniture, architectural millwork, and composite fabrication.
What table sizes are available for the Thermwood Model 45?
The Model 45 is available in five table sizes: 5'x5', 5'x10', 5'x12', 6'x12', and 7'x12'.
What spindle options are available on the Thermwood Model 45?
The Model 45 comes standard with a 12 HP HSD Spindle running 3,000 to 24,000 RPM. An 18 HP spindle is available as an option. The machine can also be configured with dual spindles for increased throughput.
Does the Thermwood Model 45 have a rotary axis option?
Yes. The Model 45 offers an optional rotary axis that accepts stock from 8 inches in diameter up to 56 inches in length, making it suitable for turning and machining cylindrical or irregular workpieces.
What tool changer options are available on the Thermwood Model 45?
The Model 45 comes standard with a 4 Position Bar Style Automatic Tool Changer. Options include a 5 Position At-The-Head Tool Changer, a 7 Position Bar Style Automatic Tool Changer, and an At-The-Head Automatic Tool Changer.
What industries use the Thermwood Model 45?
The Model 45 is used across a wide range of industries including aerospace, composite fabrication, marine and boat building, furniture, architectural millwork, cabinet production, aluminum and non-ferrous metal machining, plastic sheet machining, and military and defense applications.
