HARDWOODS - SOFTWOODS - FIBERBOARD (MDF) - PARTICLEBOARD - PLASTICS - ALUMINUM
MODEL 53
Moving gantry, fixed table, three-axis CNC router designed for the routing and stack machining of large sheet material.
Large Format Stack Machining
The Model 53 is engineered for high-volume routing and stack machining of large sheet material with optional automation.
Stack Materials
Designed to process large, stacked sheets with an optional roller hold-down system, dramatically increasing throughput.
Automate Your Workflow
Optional automatic load/unload systems allow for continuous, unattended operation, maximizing your productivity.
Massive Work Area
With table sizes up to 5'x20', the Model 53 can handle exceptionally large parts and full production runs with ease.
MODEL 53
Moving gantry, fixed table, three-axis CNC router designed for the routing and stack machining of large sheet materials such as hardwoods, softwoods, fiberboard (MDF), particleboard, plastics and aluminum.
Available Table Sizes: 5'x10', 5'x12', 5'x16', 5'x20'
Standard Features
  • 12 HP HSD Spindle (3,000-24,000 RPM)
  • Fixed Solid Aluminum Table with Moving Gantry
  • Intelligent Servo Drives Throughout
  • Thermwood SuperControl
  • Free Phone and Forum Support
Available Options
  • 18 HP HSD Spindle
  • Roller Hold Down System
  • Automatic Load/Unload System
  • Automatic Lubrication
  • Automatic Tool Length Measurement
