CNC Router Applications by Industry | Thermwood
American Made in Dale, Indiana Since 1969
Thermwood CNC routers and LSAM additive systems work in cabinet and furniture shops, plastics and solid surface fabrication, composites, aerospace, pattern and mold making and more. Find your industry to see how Thermwood machines are used and which models fit the work.
Home › Applications
21Industries and applications served
3 & 5 AxisCNC routers plus LSAM additive systems
Up to 100'Table lengths for the largest parts
1969Building CNC routers in Dale, Indiana
Applications and Industries
Every Thermwood machine is configured for the work it will do. Select an application to see how it is done and which machines fit.
Cabinets, Furniture and Wood Products
Nested-based and solid-wood production for cabinet, closet, furniture, frame and millwork shops.
High Volume Cabinet Production
Higher throughput for larger cabinet shops by combining nested-based machining with automated sheet handling. The control can merge programs from different design software into one nested job.
Nested Based Manufacturing
Cut every part of a job from full sheets in one pass, with software that arranges parts to reduce waste. Options run from the no-programming Cut Center to the fully automated AutoProcessor.
Furniture
High-volume production of furniture components from sheet stock or solid material, including chairs, tables, upholstery frames and carved case goods.
Upholstered Frames
High-speed nested production of upholstery frame parts, with a roller hold-down system for plywood or stacked sheets and optional automatic load and unload.
Architectural Millwork
Moldings, panels and custom millwork on rigid, laser-calibrated machines with flexible tooling and a large work envelope.
Residential/Commercial Construction
Doors, windows, trim, railings and post-and-beam machining on large-envelope machines that run large CAD-generated programs.
Exhibits/Store Fixtures
Flexible production systems for exhibit, store and retail fixture builders that machine wood, MDF, plastics, acrylic, composites and non-ferrous metals on one machine.
Education
Industrial CNC routers for high schools, community colleges, universities and technical training centers, so students learn on full-scale production equipment.
Plastics, Solid Surface and Metals
Sheet cutting, 3D trimming and non-ferrous machining.
Machining Plastic Sheets
Fast, accurate, smooth cuts in plastic sheet, acrylic, fiberglass and composite panels, with roller hold-down available for stack machining thinner sheets.
Three-Dimensional Plastic Trimming
5-axis trimming of thermoformed plastic, composite and non-ferrous parts, from high-speed production trimming to very large components.
Solid Surface Processing
Fast, accurate and smooth cuts in solid surface material on large-table machines with laser calibration and volumetric compensation.
Aluminum/Non-Ferrous Metal
High-speed 3-axis and 5-axis machining and trimming of aluminum and other non-ferrous metals, including molds, patterns, honeycomb core, nested sheet parts and hydroform trimming.
Composites, Patterns, Molds and Large Parts
Large-envelope 3-axis and 5-axis machining for aerospace, automotive, marine, wind energy and defense.
Composite Fabrication
Trimming and machining of composite parts, molds and patterns on machines with envelopes from about 5'x5' to more than 60 feet and spindles up to 20 horsepower.
Three-Dimensional Patterns/Molds
3-axis machines handle shallow patterns and molds without undercuts, while deeper, larger or undercut parts call for 5-axis. Volumetric laser compensation makes machining oversized parts in layers practical.
Aerospace
Machining aluminum, honeycomb, molds, patterns and composite parts for aircraft, spacecraft and defense programs, backed by laser calibration with volumetric compensation.
Automotive
Patterns, molds and prototypes for automotive design, from small parts to full-size vehicles in one setup, in wood, MDF, rigid foam, REN and most non-ferrous metals.
Marine/Boat Building
3-axis machines cut wood, acrylic and non-ferrous parts and large bulkheads, while large 5-axis systems make patterns and molds and trim fiberglass and composite components.
Wind Energy
Patterns, molds and production parts for wind energy systems, with a control that aligns programs to the mounted position of large parts.
Military/Defense
Large-envelope trimming and machining of aluminum, honeycomb, molds, patterns and composites for defense contractors.
Medical
Complete systems, developed with medical technology partners, for producing prosthetic and medical devices from laser-scanned body shapes.
Additive Manufacturing
Large Scale Additive Manufacturing for tooling, molds and large thermoplastic parts.
Additive Manufacturing (LSAM)
LSAM prints large thermoplastic parts slightly oversized, then trims them to final shape. It is used for aerospace and automotive tooling, foundry patterns, composite layup tools, marine components and wind energy.
Machine: LSAM
CNC Routers by Material
Start with what you cut. These are the Thermwood machines most often matched to each material.
Material Typical Work Machines to Consider
Plywood, MDF and particleboardNested cabinets, closets, furniture and frame partsCut Center, Model 43, Model 45, Model 53, MTR Series, AutoProcessor
Hardwoods and softwoodsMillwork, moldings and furniture partsModel 42, Model 45, Model 53
Plastic sheet and acrylicParts cut from flat sheetModel 42, Model 43, Model 45, MTR Series
Thermoformed plastics5-axis trimming of formed partsModel 67, Model 90, Model 70, Model 77
Composites and fiberglassTrimming, molds and large partsModel 45, Model 63, Model 65, Large Format, Model 67, Model 70, Model 77, Model 90
Solid surfaceFabricated solid surface partsModel 42, Model 45, Model 53
Aluminum and non-ferrous metalsSheet parts, honeycomb and trimmingModel 42, Model 45, Model 67, Model 70, Model 77, Model 90
Foam, REN and tooling boardPatterns, plugs and moldsModel 63, Model 65, Large Format, MAX 5, Model 67, Model 70, Model 77, Model 90
Printed thermoplastic compositesLarge tooling, molds and patternsLSAM
Matching a Machine to Your Application
The shape of your parts decides the number of axes. Flat parts cut from sheets point to a 3-axis CNC router. Formed or three-dimensional parts that need trimming or contouring from several angles point to a 5-axis CNC router.
Part size decides the table. A 5'x10' table covers most sheet work, while large composite parts, patterns and molds may need a large-bed machine such as the Model 63, Model 65, Large Format or MAX 5. For very large tooling and molds, LSAM prints the part and trims it to final shape.
Production volume decides the automation. Tool changers, dual spindles, drill banks, labeling and automatic loading and unloading all raise throughput. For a complete guide, see How to Choose the Right CNC Router.
CNC Router Applications FAQ
What industries use Thermwood CNC routers?
Thermwood CNC routers are used in cabinet and closet production, furniture, upholstered frames, architectural millwork, construction, exhibits and store fixtures, plastics, solid surface, aluminum and non-ferrous metals, composites, aerospace, automotive, marine, wind energy, military and defense, medical and education. Thermwood's LSAM systems add large scale additive manufacturing for tooling, molds and patterns.
What is the best CNC router for a cabinet shop?
Most cabinet shops use a nested-based 3-axis CNC router with a 5'x10' table. The Cut Center runs Cut Ready software, so there is no CNC programming. The Model 43 and Model 45 are high-performance nested-based machines, and the AutoProcessor and MTR Series add throughput for higher-volume production.
Which CNC routers are used for aerospace and composite parts?
Aerospace and composite manufacturers typically use 5-axis CNC routers such as the Model 67, Model 70, Model 77 and Model 90 to trim formed parts and machine molds and tooling. Large-bed machines such as the Model 63, Model 65, Large Format and MAX 5 handle very large composite parts and patterns.
Can a CNC router trim thermoformed plastic parts?
Yes. A 5-axis CNC router can tilt and turn the tool to follow the edges and openings of a formed part, so it trims thermoformed plastic and composite parts in one setup. Thermwood's Model 67 and Model 90 are built for high-speed trimming, with single or dual moving tables.
Can a CNC router cut aluminum?
Yes. CNC routers cut aluminum and other non-ferrous metals, including sheet parts, honeycomb core and hydroformed parts. The Model 42 and Model 45 handle aluminum sheet work, and 5-axis machines such as the Model 67, Model 70, Model 77 and Model 90 trim and machine three-dimensional aluminum parts. For steel and other hard metals, a CNC mill is the better choice.
What is the difference between a CNC router and LSAM?
A CNC router is subtractive. It removes material from a sheet or block to make a part. LSAM (Large Scale Additive Manufacturing) is additive. It 3D prints a large thermoplastic part slightly oversized, then trims it to its final shape. The LSAM Flagship prints and trims on the same machine, which makes it well suited to large tooling, molds and patterns.
Do schools use Thermwood CNC routers?
Yes. High schools, community colleges, universities and technical training centers use Thermwood CNC routers such as the Model 42, Model 43 and Model 45 to teach CNC programming and operation on full-scale production equipment. Thermwood provides eCabinet Systems software free for classroom use. See Education.
Find the Right Machine for Your Application
Tell us what you make and the materials you cut, and our applications team will help you find the right Thermwood machine. Call 812-937-4476 or send us a request below.
