The CabinetShop Series combines all the elements needed for a custom cabinet shop to design and machine custom cabinets, custom furniture and support products.
Entry level three axis for nested-based custom cabinets, custom furniture and support products
Heavy-duty three axis available in either single or dual spindles with optional rotary axis
High-throughput automatic load/unload nested based production of cabinets, closets and custom furniture.
Complete three axis CNC routing systems with single or dual in-line tables for nested base, composite or plastic sheet material.
The Multi-Purpose Three Axis Series are highly flexible, making them ideal for a variety of manufacturing applications.
Moving table, fixed gantry primarily designed to machine low-profile materials such as hardwoods, softwoods, fiberboard (MDF), particleboard, plastics and aluminum.
Moving gantry, fixed table, (optional roller hold down) three-axis CNC router. Designed for the routing and stack machining of large sheet material such as fiberboard (MDF), particleboard and plywood
Large bed three-axis CNC router with moving bridge and stationary table. Primarily designed for two dimensional machining of large composite parts, and is also highly recommended for the machining of three dimensional patterns.
Moving gantry, fixed 4'x8' table, with 4-roller hold down, three-axis CNC router. Designed for routing and stack machining of large sheet material such as fiberboard (MDF), particleboard and plywood. With individually programmable table side bars for ease of sheet positioning and unloading and a built-in chip collection hood that cleans the table as it executes the automatic load/unload cycle.
Moving gantry, fixed table, with roller hold down, three-axis CNC router. Designed for the routing and stack machining of large sheet material such as fiberboard (MDF), particleboard and plywood.
The APM Series are designed for quick panel insertion for the aerospace and satellite industries.
Designed for quick panel insertion for the aerospace and satellite industries.
Award winning machine for custom cabinets, closets, furniture and much more with No Programming!
